Been a looooooooong time since I saw these. Can you bend up a bit of 12x3 steel to test?
Not so sure running from the stem would work with suspension. Cable will have variable pull with movement. Why the dislike for V's?Hey there vintage gurus, does anyone know if there's a whatsit or thingymabob that I can bolt to the fork arch of my old Judy's to get my even older Canti brakes going?
I'd prefer to avoid using v brakes and I don't have enough steerer length to use one that mounts to that. I could drill through the stem as a last resort, but there's a hole in my fork arch so I figure something could conceivably be mounted there...
you're absolutely right, going from the stem or steerer wouldn't work! looks like its a fork arch solution or nothing.Not so sure running from the stem would work with suspension. Cable will have variable pull with movement. Why the dislike for V's?
The utter joy of adjusting cantis to get the same pull on both side will give you hours of fun and also pull your OCD strings at the same time.not so much a dislike for V as much as just wanting to run canti's. I remember being sooooooo jealous of mates that had canti's back in the early 90's, so now i can track them down and lord this over them
Nah, they are shite. I swapped cantilever to vee for immediate improvement.The utter joy of adjusting cantis to get the same pull on both side will give you hours of fun and also pull your OCD strings at the same time.
They do work well once they are adjusted just right.
Sshhhh.... @Plankosaurus might hear you.Nah, they are shite. I swapped cantilever to vee for immediate improvement.
I'm just hoping that there is a disc on the rear just in caseIt's all good. I didn't buy a 25 year old bike for its cutting-edge ride quality
Stick through spokes.I'm just hoping that there is a disc on the rear just in case
@Plankosaurus have you seen this discussion?you're absolutely right, going from the stem or steerer wouldn't work! looks like its a fork arch solution or nothing.
Thanks mate, had not seen that and it unfortunately makes some sense reflectors on the arch was a thing back then wasn't it? I'd hate to break the forks just because I want to use inferior brakes@Plankosaurus have you seen this discussion?
If your hell bent on running canti's I have an old set of canti Mach V's taking up space in my shed you can have.Parts Help: Rock Shocks Cantilever Brake Cable Mount
www.mtbr.com
Awesome, we have to do a retro burn around Lysty now, once we can again.V up front and Canti out back. This is going to shit me to tears till I find a solution to get a V brake on the rear (the cable guide won't really work for V, there's nowhere to fit an outer cable)
But it's ridable, and super nostalgic
(The first MTB I bought myself was a barracuda, and it got stolen off the back of my ute in my early 20s when I failed to secure it with anything more than ropes)
I'd still like to ditch the grip shifter for some triggers, and get some matching Araya rims on it because they were apparently the bees knees when I was in high school.
Colour me keenAwesome, we have to do a retro burn around Lysty now, once we can again.
Though I did managed to break my front V-brake recently so going to have to get on the hunt for a replacement at some stage.
That would be awesome.Colour me keen
I can probably sort you out with a v brake too, how fussy are you on them?
I have a matching pair of these on that little Avanti hammer, swap you for that solo avid one if you want?That would be awesome.
Not fussy at all mate the rear is still just some old base model avid.
Sounds like a plan!I have a matching pair of these on that little Avanti hammer, swap you for that solo avid one if you want?
