The Duckmeister
I suspect this is the likely scenario. Worth a try on a lower-profile adaptor, they're only $a few.Or maybe 180 mounts on frame when old ole was 160?
IS tabs are standard as far as spacing goes, but can be placed at different heights on the frame or fork depending on the manufacturer's minimum rotor size spec. Adapting for a larger rotor requires both lifting the caliper further from the frame/fork, and tilting the caliper forward lengthwise to match the rotor curve.Is that a thing with IS mounts though? I don’t recall ever seeing or hearing of different rotor size IS mounts.
Just confirmed the IS mount holes are on a different radius between the frames. Learn something new every day.IS tabs are standard as far as spacing goes, but can be placed at different heights on the frame or fork depending on the manufacturer's minimum rotor size spec. Adapting for a larger rotor requires both lifting the caliper further from the frame/fork, and tilting the caliper forward lengthwise to match the rotor curve.
Have you got one? I reckon some of us might have one in the parts bin, I know I used to...Just confirmed the IS mount holes are on a different radius between the frames. Learn something new every day.
Caliper seems to be out by 10mm so a PM160 rear adapter should sort it out from my guess
If someone has one that is no longer required it would help a lotHave you got one? I reckon some of us might have one in the parts bin, I know I used to...
After reading your thread it would seem that our issues are similar yet different.That would be me, yep.
Yeah seems to be a bit of a theme. Interestingly the first frame I had didn't have any issues, at least from memory.After reading your thread it would seem that our issues are similar yet different.
Interestingly, my sliding dropout Marino hardtail had a warped brake mount which caused some grief, particularly since it is alloy and the only other person I have met with a Marino (which was years ago now) also had a problem with the rear brake mount.
Doubt you'll get anywhere, but try sending an email and pics to them. Surprising how often this is to result in a credit certificate being issued.
Don't you know aero when you see it?
Maybe I should be one of those a-holes that shuffles through all the bread and make a mess.Doubt you'll get anywhere, but try sending an email and pics to them. Surprising how often this is to result in a credit certificate being issued.
Areo isn't going to help my sandwich stay together.Don't you know aero when you see it?
that's what your hands are for. Something wrong with your hands too?Areo isn't going to help my sandwich stay together.
But you'll eat it so fast the sandwich won have time to fall apart.Areo isn't going to help my sandwich stay together.
At first I thought they looked like dancing sheets, the more I studied them though they have a dancing penis look about them.
No, that’s a standard shock in a Specialized yoke.Also, do I need a special type of shock if I buy this frame. Like the mounting of the shock looks strangeView attachment 390597
