Not sure of the cost but a decent locksmith sould be able to cut a new key from the barrel. They have tools to measure the pin heights.Does anyone know if the number on the cylinder of a Thule lock relates to the key number?
I bought some Thule roof mount carriers last night sans keys. Lots of stuff on the Web says the key number is on the face of the cylinder where the key inserts but that is not the case with these.
I managed to extract one of the cylinders as it wasn't locked and can see the number in the pic.
If you go to a Thule dealer they have all the keys on hand to match your rack.Not sure of the cost but a decent locksmith sould be able to cut a new key from the barrel. They have tools to measure the pin heights.
Yep, I like them for the long distance rides with a rigid fork, they take a bit of the harshness out. I actually got these from Ali and they're fairly thick.Anyone tried foam handlebar grips?
Yay? Nay?
Thank you!Yep, I like them for the long distance rides with a rigid fork, they take a bit of the harshness out. I actually got these from Ali and they're fairly thick.
https://www.aliexpress.com/item/327....order_list.order_list_main.70.7dd71802MtKTM3
Yay on the fatbike.Anyone tried foam handlebar grips?
Yay? Nay?
Exactly this, also great for going gloveless on said long distance ride as they don't get slippery.Yay on the fatbike.
Just asked my WWE tragic workmate and yep, apparently that's correct. Also heroes are referred to as 'baby faces'
I meant 5 down. Edited the pic.Just asked my WWE tragic workmate and yep, apparently that's correct. Also heroes are referred to as 'baby faces'
Mate just saw my seriously confused face and apparently "wrestling has its very own parlance that makes no sense."
Checks out.
and a little bit poufy...Poofy and white
coilcool!
That too!coil
It's happening, local tribespeople have been murdered to clear the way.is this fair dink ?
NEOM: Made to Change
Discover NEOM: an opportunity of unprecedented scope for sustainable living, technological innovation and human progress.www.neom.com
