You could use reusable nylon straps for the bottom couple of stacks. If you have rectangle shape boxes, store the next layer with the cans upright but at 90 degrees. You can get corner boards to keep the stack aligned too, the leaning tower is all good until it falls on someone.Hmmmm...made switch to cans to reduce non-recyclable waste, so no plastic wrapping them. Not meant to store beer sideways either, but aren't carrying big stock levels for long periods of time so it might be ok and is a likely solution to the leaning tower it currently is.
