Correct - 6mm is for 142mm non-boost.DM chainrings.
6mm is non boost and 3mm boost?
Looking to purchase a crankset for a non-boost frame, so my thinking is I need 6mm offset chainring...
Thats not a bad quote at all.Soooooooo. 1997 Mitsi Mirage - 125000 kms. Engine feels like it goes well but all this crap.
Tyres are okay.... front struts - look fucking expensive. Is it worth it? I know it's not but the son needs a car.
Or see if standard 6 or 8mm wiper blade inserts will fit the head. They should be <$10 per insert.Otherwise do the wipers yourself and get the rest done at the shop?
Are you buying the car, or do you already own it?Soooooooo. 1997 Mitsi Mirage - 125000 kms. Engine feels like it goes well but all this crap.
Not sure many people would have spring compressors and decent jack-stands on hand for doing front struts. The rest of the stuff seems pretty reasonably priced IMO. The workshop can make money, but doesn't look to be trying to gouge @indica by any means.Many people could swap all those parts in an afternoon, that era of Japanese cars is great for DIY maintenance.
Don’t need spring compressors - zip ties for the winNot sure many people would have spring compressors and decent jack-stands on hand for doing front struts. The rest of the stuff seems pretty reasonably priced IMO. The workshop can make money, but doesn't look to be trying to gouge @indica by any means.
It's all good until it isn't.Don’t need spring compressors - zip ties for the win
True that. There is brake bleeding too, even if you can do it with only a jar and some aquarium hose. It can be easy to do, but I found it really annoying the first few timesNot sure many people would have spring compressors and decent jack-stands on hand for doing front struts. The rest of the stuff seems pretty reasonably priced IMO. The workshop can make money, but doesn't look to be trying to gouge @indica by any means.
Free skylight in the shed, or cat door in the wallDon’t need spring compressors - zip ties for the win
Kinda what I was looking for and cheers.but doesn't look to be trying to gouge @indica by any means.
Already own itAre you buying the car, or do you already own it?
My daughters car went for a service at Holden and they wanted $2900 for a thermostat / engine mount / battery replacement - it had an extended warranty as she lives away from me we thought good idea - ended up costing her nothing - however if she had to pay for it I could have easily bought any specialty tools needed and the parts and been in front by over $1500 - being able to do mechanical work is a huge advantage in life IMHO.Kinda what I was looking for and cheers.
Already own it
Thank heaps all for the replies. I am mechanically retarded - not a hope in hell of doing any of that myself.
Is 0.4mm extra width (0.2 each side) going to give me issues witb my RF BB bearings?
For context:
Changed to 24mm ID bearings to do away with the plastic shim/sleeves however the enduro outboard dust seals are 0.2mm thicker than the plastic sleeve/dust covers which to me means more preload on the bearings. I removed a spindle spacer, but the cranks were harder to spin than with the spacer left on.
- Spacer on, cranks spin about three times. Crank bolt nipped up.
- Spacer off, cranks spin about once. And the crank bolt isn't even nipped up.
