Jason, Jason, Jason.Beet your meet?
Use a designed for this purpose expanding puller, in lieu of spending hundreds of $ a masonry anchor that you wind out to pick up the ID. Then pulllllll.I've done it with a Dremel and cutting disc.
I know. I know..Jason, Jason, Jason.
Of course not...nobody would want that.cock in the hole.
Tried the old expanding cock trick?Of course not...nobody would want that.
Once...it's both an hilarious and tragic story too long and not suitable for this forum, while also being an outrageous boast.Tried the old expanding cock trick?
That sounds like a solid idea, I'll measure up what's left of the bearings and see if Bunnings have something big enough to workUse a designed for this purpose expanding puller, in lieu of spending hundreds of $ a masonry anchor that you wind out to pick up the ID. Then pulllllll.
Have blowtorch, can hotifyHeat is your friend. After heating it up you may be able to pry the bearings out by very carefully using a screwdriver with the tip in the bearing groove. If you can get it to move slightly, then go around in very small increments as you don't want the bearing to cock in the hole. Otherwise, as Dales says, get an expanding masonary anchor that fits, but you don't need to pull - just hammer it out using a drift from the other side.
Where is Plank and what have you done to him?Only thing I'd worry about is heating it too much and annealing the aluminium. I'll have to be careful with the application of hots
He's annealed aluminium before, and he doesn't want to ruin a potentially very difficult to replace linkage. Too much hots makes aluminium softer than stans crest rimsWhere is Plank and what have you done to him?
That takes a LOT of heat! Soft flame and you're fine.He's annealed aluminium before, and he doesn't want to ruin a potentially very difficult to replace linkage. Too much hots makes aluminium softer than stans crest rims
I've used a butane torch in the past and managed to make alloy more malleable than i wanted, I'd hazard a guess that the map torch would apply more hots than the cheapo butane one that cant melt silver solder.That takes a LOT of heat! Soft flame and you're fine.
We use these all the time at work and have never had an issue:
Nice 'fluffy' flame.
MAP can melt 6000 series aluminium.I've used a butane torch in the past and managed to make alloy more malleable than i wanted, I'd hazard a guess that the map torch would apply more hots than the cheapo butane one that cant melt silver solder.
I'll give it a whizz gently and see how i go
I'll be waiting patiently in the fwits thread.What's the worst that could happen?
Put a bit of oil on the ally, heat gently and if the oil starts smoking, STOP. Your goal is to heat the whole thing, the aluminium has about twice the CTE of steel so as you go up in temp, the degree of interference fit is reduced. Actually, I have an idea that might work, PM incoming!What's the worst that could happen?
