4dabush
Few more Cylinders in this one than an Opel…That’s one of those Opel knockoffs made in the colonies?
Quantity over quality?Few more Cylinders in this one than an Opel…
Very nice, not many 2 doors around now.What’s been keeping me busy and off the bike. View attachment 403590
Resto-mod, so injected alloy headed 304, T5 5speed, 9inch with fully adjustable trailing arms, 4 wheel discs with Hoppers 290mm discs up front, Koni/Kings suspension, 16inch super light wheels, AC, full leather trim based on late Honda style using modded Gemini and i30 seats... only things I have not done myself is trim and motor…only didn’t do the motor as I spent too much to risk and blueprinting compared to dollars into it made lots of sense. I’ll probably get a hand with the wiring and AC I obviously can’t gas at home.Very nice, not many 2 doors around now.
What's the engine plan?
Very nice, will be awesome.Resto-mod, so injected alloy headed 304, T5 5speed, 9inch with fully adjustable trailing arms, 4 wheel discs with Hoppers 290mm discs up front, Koni/Kings suspension, 16inch super light wheels, AC, full leather trim based on late Honda style using modded Gemini and i30 seats... only things I have not done myself is trim and motor…only didn’t do the motor as I spent too much to risk and blueprinting compared to dollars into it made lots of sense. I’ll probably get a hand with the wiring and AC I obviously can’t gas at home.
Is that the proper tangerine?What’s been keeping me busy and off the bike. View attachment 403590
Awesome guess, yes, 100% Dulon AAA, painted where you see it. I’m not good with 2k and while painting at home is a no no, acrylic is a little less offensive.Is that the proper tangerine?
I've mentioned it before, my uncle had an XU1 in that colour. Until someone decided they wanted it more than he did. He was devastated.Awesome guess, yes, 100% Dulon AAA, painted where you see it. I’m not good with 2k and while painting at home is a no no, acrylic is a little less offensive.
You should be able to sell the auto. Probably worth $3.00Making progress with the 5 speed conversion.
Goodbye dirty dirty auto:
Hello new Tremec:
Gearbox level:
Drivetrain appears straight (harmonic balancer to diff pinion):
All that's needed is to refit driveshaft (got it rebuilt and balanced by Hardy Spicer), hook up clutch cable, wire in the neutral safety switch and reverse lights and fill box with oil.
I suspect the exhaust will foul the bellhousing, so I'll see if I can persuade it with the blow torch and hammer as a short term fix.
Edit - fitting the gearbox was one of the most infuriating and swear inducing things I have ever done. The clearance isn't enough to slide the input shaft past the pressure plate fingers, so had to sort of jack it up at an angle and push it forward at the same time to force it past the fingers. Then try to match the box angle with the motor (has to be 100%), then at the same time slightly wiggling the output shaft and trying to push the box forward to engage the clutch splines. Sounds dirty haha.
$6You should be able to sell the auto. Probably worth $3.00
I have the nose off the track car, map or other (one code suits many). Suspect lack of volume so I am fitting a vacuum vessel. Oh what fun pulling itbs off a fwd car.Making progress with the 5 speed conversion.
Hello new Tremec:
Gearbox level:
I bet they got a small perceived quality in the shifter feel with the rubber bit. Sometimes engineers need to be held down and stopped from fiddling!Just thought I would share this frustration here.
On my auto CX5 when you put it in park the gear stick shaft presses a button to let the car know it can be switched off. Mazda decided to make the switch out of plastic but with a rubber tip for some reason. Over time the tip wears a groove in the rubber meaning when you put it in park, even though the engine can turn off, all of the accessories like aircon and radio stay on draining the battery. As it gets worse you have to smash it across harder or force it in position to get it to switch off. I had seen you could buy the replacement part, which is now fully plastic, but when I took my switch out I ripped off the rubber piece which left a hole in the plastic. I put a small cable tie through the hole with the knob where the groove was and then another cable tie around the plastic switch to keep the first cable tie knob poking up. Works perfect.
