dazz
Downhill Dazz
They have Freeza tech in the 180 and 203 as well:Dura-ace icetec freeza, those are road only with sizes 140mm & 160mm.
https://www.mtbdirect.com.au/products/shimano-xtr-rt-mt905-ice-tech-freeza-6-bolt-disc-brake-rotor
Yeah I have them on my Spur and Deviate.They have Freeza tech in the 180 and 203 as well:
From a feel perspective, many little holes are prefereable IMO. Slots tend to feel a bit notchy or prone to locking.The burning question for me:
Is there an optimal rotor hole shape (round, rhombus, dick shaped etc) and do the holes suit different pad shapes/brake manufacturers or are the manufacturers just making their holes different, just to be different?
It was a standard Hope 203mm floating rotor with Shimano sintered pads running Saint 4 pots.I assumed the primary reason for the drop in mu at high temps was more to do with the rotor material than the pad material. Seems I learned something, thanks.
Can you post pics of your rotors, Oddjob? I'd like to see the pattern used.
I still don't think the slots/holes primary function would be to ventilate the gases under the pad, more so to dissipate heat from the rotor to prevent sublimation in the first place.
As heat dissipation is primarily about surface area, lots of smaller holes/slots is better than fewer large holes. BUT! Small holes clog with mud more easily, negating the cooling effect. The holes also need to be large enough to get a reasonable flow of air through them.
I just had an idea!!
Perhaps you have a favourable body type to test a spoke mounted cooling fan. As the wheel rotates, air is directed at the rotor?
*Edit*
https://www.bendix.com.au/news-events/what-causes-brake-fade-and-how-to-minimise-it
https://alconkits.com/drmassets/Brake-Fade-Solved.pdf
I'm a bit of a cheap fuck so have tried many many cheaper rotors and most of them work fine. Honourable mentions got to Uberbike, Discobrake and even the Lifeline and Clarks rotors.From a feel perspective, many little holes are prefereable IMO. Slots tend to feel a bit notchy or prone to locking.
I wondered about different metal compositions of the discs too. Formula 'Monolithic' rotors are bitier than Hope rotors (in same diameter/thickness)
+1, I am always trying to tweak those Shimano rotors back into shape and I don't overly hit the brakes. Solids only seem to get a tiny bit on warpage in comparison.Have absolutely munted Shimano freezas so avoid them, and tend to warp solid discs pretty quickly. Floating rotors tend to stay straighter for longer, even after abuse.
Buff! BUFF!!+1, I am always trying to tweak those Shimano rotors back into shape and I don't overly hit the brakes. Solids only seem to get a tiny bit on warpage in comparison.
Best of luck with bypass. People I've known that have had it done have had good results. You will be buff in no time.
Buell FTWWill be back to rim brakes in no time
This is going to look great on the Ti hardtailNew Mattocs look like a great package. A mini Mezzer, MC2 damper up to 150mm travel and 1750g.
Mattoc Pro
The new Mattoc is the fruit of one of the most profound development cycles in Manitou history. It is the physical embodiment of “great things take time”. It is not an offering that follows the crowd, designed around the latest trend or buzz of the market. Rather, a component that aims to add...hayesbicycle.com
Interested to see how the 34mm plays out with current marketing of bigger stanchions is more betterer. The previous Mattoc was a great fork and this looks to be a solid update.New Mattocs look like a great package. A mini Mezzer, MC2 damper up to 150mm travel and 1750g.
Mattoc Pro
30% stiffer apparently. Having ridden the previous gen Mattocs. They were great for compliance/stiffness. I think this update will be spot on for the targeted category.Interested to see how the 34mm plays out with current marketing of bigger stanchions is more betterer. The previous Mattoc was a great fork and this looks to be a solid update.
I found the Mezzers were a bit to much for the trail bike (at 140mm they were really tricky to get right) but this sounds like it will be what I've been looking for. And they are almost the same weight as a Sid30% stiffer apparently. Having ridden the previous gen Mattocs. They were great for compliance/stiffness. I think this update will be spot on for the targeted category.
Mezzers are only a touch over 2kgs if want that additional stiffness.
Love the gloss lowers...just everything reallyNew Mattocs look like a great package. A mini Mezzer, MC2 damper up to 150mm travel and 1750g.
Mattoc Pro
Practically the same thing.I'm a bit of a cheap fuck so have tried many many cheaper rotors and most of them work fine. Honourable mentions got to Uberbike, Discobrake and even the Lifeline and Clarks rotors.
The only rotors that I haven't done well with are these weird Lifelines that really thin out between spokes. I'll try and get a picture of them.
