How good is it knocking off at 3:30?Hmmm....can anyone else see the problem here?
Yeah, I go to bed at 2am but either way there is no need to start at 7am especially with all the juvenile carry on that seems to be common place on most sites.Hmmm....can anyone else see the problem here?
It isn’t their fault you go to bed at 2.Yeah, I go to bed at 2am but either way there is no need to start at 7am especially with all the juvenile carry on that seems to be common place on most sites.
But it is their fault they’re inconsiderate pricks making anyone not keeping their hours lose sleep…It isn’t their fault you go to bed at 2.
You know they only do it because they know you are next door right.But it is their fault they’re inconsiderate pricks making anyone not keeping their hours lose sleep…
Well…you can’t make 203 mounts when some fools run 200. Do you even standard?203mm rotors but 200mm fork mount
Honestly people
Ah you just reminded me of one of my all-time favourite pieces of standup comedy:Lady over the road is renovating an old cottage ( think late 1800’s ) , I don’t mind the banging and what not .
It’s her teenage kids calling
“ mum , muuummm , muuuummmmm , where is my whatever “
What even goes through someone’s mind to make a 203mm rotor as standard? It’s not even an imperial conversion. And then you need to get 1.5mm spacers. So dumb.Well…you can’t make 203 mounts when some fools run 200. Do you even standard?
My fork mount is 203 and I wanted to run 220 rotors so I had to find a +17 adaptor FFS203mm rotors but 200mm fork mount
Honestly people
I reckon 203 was around before 200. At least as I recall.What even goes through someone’s mind to make a 203mm rotor as standard? It’s not even an imperial conversion. And then you need to get 1.5mm spacers. So dumb.
Pfft. Just use 17 0.5mm washers on each mount. That’ll learn ya.My fork mount is 203 and I wanted to run 220 rotors so I had to find a +17 adaptor FFS
It is actually. 8" is 203.2mm. 180 & 160mm are both further from their suggested imperial conversions.What even goes through someone’s mind to make a 203mm rotor as standard? It’s not even an imperial conversion.
Correct. Though 180 is close enough to 7” to barely matter. 160 is a nothing burger though. Only of use on kids bikes.It is actually. 8" is 203.2mm. 180 & 160mm are both further from their suggested imperial conversions.
Hence why avid brought out the 185...It is actually. 8" is 203.2mm. 180 & 160mm are both further from their suggested imperial conversions.
Really? 7,25”?Hence why avid brought out the 185...
My car has a super old navigation system that doesn't have certain things in it like roads built since 2010. So when those get used it totally wigs out and suddenly on the screen you're in a flying space car and every time you go near an overpass it starts shrieking nonsensical babble about needing to do a u turn in the next 10kms or something.Modern cars that are hooked up to the Internet for all their navigation systems et cetera, but don’t automatically update their clocks for daylight savings.
