気が狂っている男
Hammer it out. A few firm hits should drive it out.
Drilling the tail of the bolt is very effective. Sometimes the heat/vibration will loosen the loctite, and sometimes the bolt can even be threaded out from the mangled end as there's nothing supporting the threads and they can deform away from what they're threaded into.So annoying that bike manufacturers still use weak/soft bolts at all!! Some brands have it all worked out, and some just don't seem to care.
Try drilling a 3 or 4mm hole into the opposite/threaded end of the bolt and screwing in a smaller size bolt, then tighten to extract from linkage...
More hammeris the thread likely to be buggered, whats the answer for fixing that ?
Not yet that's tonight's episode of tales from the fwit.Have you had a crack with the torx bit yet?
of course !!!More hammer
I have this stuff, have gone through a whole can trying it on various things and it has not helped ONCE.Whichever method you use to get some purchase into the bolt to unscrew it, I highly recommend Loctite Freeze n Release spray. give it a good blast then try unwinding the bolt.
Maybe you didn't spray enough on LOL. Needed 2 cans perhaps.I have this stuff, have gone through a whole can trying it on various things and it has not helped ONCE.
Don't use it in the nude. The slightest touch yields much less hammer.Whichever method you use to get some purchase into the bolt to unscrew it, I highly recommend Loctite Freeze n Release spray. give it a good blast then try unwinding the bolt.
And you know this how exactly?Don't use it in the nude. The slightest touch yields much less hammer.
Excellent advice Poodle sounds like it's from personal experience?Don't use it in the nude. The slightest touch yields much less hammer.
funny you say that! check out this repair on a busted shock pin!So annoying that bike manufacturers still use weak/soft bolts at all!! Some brands have it all worked out, and some just don't seem to care.
