Cardy George
How often does it rain in your bedroom?
I'm sure it covers dry and dusty conditions too...How often does it rain in your bedroom?
Are you telling me that water based lubes aren't any good for riding outside?How often does it rain in your bedroom?
Ur right, there’s no rubber rings on the chain.Does anyone use gearbox oil, as used on old (and apparently new) motorcycle chains?
Here's a 'test' video comparing dedicated motorcycle lubricants against gearbox oil, WD-40 and cooking oil spray, for some reason.
Never Buy Chain Lube Again? Comparison Test - YouTube
I'd imagine the same principals can be applied here, but we also have the shifting of gears to worry about, which adds a lateral force to the mix?
My understanding of chain construction is that there's no 'O' or 'X' rings to hold in lube from the factory as in modern motorcycle chains, it's just links, pins & rollers, like an older plain metal on metal motorcycle chain?
Speak for yourself! But it also usually needs a clean after the lube has been applied.Ur right, there’s no rubber rings on the chain.
You could use gearbox oil but dust will just stick to it and look like Pome toilet after a vindaloo.
treat it like ur wang. U wouldn’t put lube on it without cleaning it first.
Fantastic advicetreat it like ur wang. U wouldn’t put lube on it without cleaning it first.
I have quietly road tested the fine @pink poodle Lanox on the chain idea. Works well so far and seems to keep things quiet.Prepare to be offended you lube snobs..! I get endless kilometres from a quick squirt of the good stuff once every couple of weeks. I live very close to the beach so cop salt air and sea spray, ride pretty much every day, get rained on frequently, trails are very dry and dusty, never measure or rotate my chain until is absolutely rooted, clean it with a squirt of the same stuff I lube it with or sometimes WD-40! Other than installing a new chain when building a new bike I can't remember the last time I swapped out a chain.
I definitely get longer lasting benefits from the Inox over silicone.
Next minute, the Rams are chasing you.I have quietly road tested the fine @pink poodle Lanox on the chain idea. Works well so far and seems to keep things quiet.
It must be a bit more water resistant and that great sheep smell is what everyone needs more of.
At least you are lubed up if they catch you.
I'm a big fan of Rambro - bless his dearly departed heart.Next minute, the Rams are chasing you.
We used to stir a billy goat up when I was a kid, it got me through a chainwire fence one day and sent me for six, had much more respect for Mr billy goat after that.I'm a big fan of Rambro - bless his dearly departed heart.
Get 'em Rambro.
Which RnR are you using?So, originally was on rock n roll, then onto squirt. I think you get more miles out of squirt but does gunk up after a while.
Last couple of months been using both on the one chain. Firstly I apply a bit of squirt, give it a spin through the gears, then rock n roll, spin again then wipe off the excess.
Have to say so far so good, minimal gunk and good km’s.
Anyone see any probs with this?
I'm using RnR (gold) and Squirt at the moment and would do it the other way around, mainly cos RnR seems to be quite a strong cleaner so would likely remove the squirt you just put on. Always apply squirt the day before and let it fully dry, never apply straight before a ride.So, originally was on rock n roll, then onto squirt. I think you get more miles out of squirt but does gunk up after a while.
GoldWhich RnR are you using?
Yeah, the gold is a dryer lube and doesn't last very long, the blue is a lot better because it lasts longer.Gold
What type of chain life do you get, what brand of chains, and what roughly are the intervals of lube application? (road or MTB)I've been using Silca Synergetic and it has been outstanding. Seems expensive but you use so little of it, its going to last quite a while.
Silca Synergetic - Zero Friction Cycling
Product info from Silca; What is it? The Ultimate Oil Based Lube SILCA's new oil-based lubricant based on technology originally developed in F1 racing, to reduce friction and nearly eliminate wear in all metal components. Who's it for? This lube is for the demanding cyclist who wants to...zerofrictioncycling.com.au
