Funny thing is it was the sort of thing you’d brush of your arm without a thought.Yikes. Sounds like a hardcore bug.
A quick Hambo suggests it was a spider wasp. Didn’t look very scary.
Just did a Hambo and yeah doesn’t look too menacing. Adds to list of bugs to worry about while in the bush.Funny thing is it was the sort of thing you’d brush of your arm without a thought.
Just did a Hambo, and unless you're a spider you don't have to worry; they're not aggressive to humans and only sting if extremely provoked.Just did a Hambo and yeah doesn’t look too menacing. Adds to list of bugs to worry about while in the bush.
Ooooo, I found one dragging a paralysed huntsman into its burrow in my garden one day. I sat down and watched it a while. It was very particular about the outside of the burrow and kept coming out to make adjustments, for the guest, I suppose.Funny thing is it was the sort of thing you’d brush of your arm without a thought.
We get these wasps here occasionally. Lunch is a lot of effort. I sure don't want to mess with that wasp.Ooooo, I found one dragging a paralysed huntsman into its burrow in my garden one day. I sat down and watched it a while. It was very particular about the outside of the burrow and kept coming out to make adjustments, for the guest, I suppose.
Spotto at the You Yangs today... Hourly rates too
Yeah, but name this kind of spiderDefinitely a Wolfie. Come in a variety of colours and sizes, ground dwellers, have two larger forward facing eyes. Afaik, the only spider that carries it's bubbies on its back. Apparently no real danger to people, but can be bad for doggos.
Plenty of people mistake them for huntsman's (wall puppies) and vice versa. They can both be big and brown and fast, but wall puppies tend to live in trees and houses where the wolfie usually won't go inside because there's not much undergrowth and holes to hide in.
Sent from my Pixel 5 using Tapatalk
Oh, that wasn't a bite...
That looks suspiciously like an old school ash tray hole.
It is a handy spare if you lose a brake rotor bolt. Keep it for another day.But what happens when you undo that torx bolt inside the hole @Cardy George ?
I never did on our deck. Used Cabot's Aquacoat that is fine to go over the top of the earlier oil.Do I really need to strip off decking oil before recoating?
I never have. Just give it a really good clean with a power washer and let it dry completely before new application.Do I really need to strip off decking oil before recoating?
Depends. If there is no peeling or flaking and deck looks to be in good order a thorough clean and dry and oil is a ok. If it is looking tatty removing the current coatings is a good start then assessing from there. I used a deck specific stripper and cleaner as after 8 odd years was looking a bit tatty then re-oiled. The other option is sanding.Do I really need to strip off decking oil before recoating?
Tiling. Our deck used to cop a lot of heat in summer. The shaded part vs. exposed part sure looked better.The other option issanding.
