Lucaw
Next in line
What could go wrong?View attachment 382078
Yes.Did it blow up before or after he hit the tree?
But why? What is wrong with people FFS.What could go wrong?
But I wanna swatbox, why can't I have a swatbox? Youse MTB people are mean.But why? What is wrong with people FFS.
MTB direct sell it but there are some products similar in electrical shops to water proof wiring.Where can I easily buy the 50mm 3m rubber mastic tape from these days? Or has the world moved on since then, and there is better stuff. Is element14 the only option? Don't know I need anything else from them, and it's $15 post.
I don't want expensive custom cut frame protection kits. Just some rubber tape I can use for chainstays and down tubes across a number of different bikes.
@ozzybmx linked to some similar stuff from Bunnings a while ago but I can't think of the name of it.Where can I easily buy the 50mm 3m rubber mastic tape from these days? Or has the world moved on since then, and there is better stuff. Is element14 the only option? Don't know I need anything else from them, and it's $15 post.
Self amalgamating tape@ozzybmx linked to some similar stuff from Bunnings a while ago but I can't think of the name of it.
Cheers.Self amalgamating tape
Self Amalgamating Tape - 10m Nitto | Jaycar Electronics
This insulating tape will cure into a single mass (once applied) to help seal and waterproof cable, wires or even pipes. The tape has good corona re...www.jaycar.com.au
Nitto tape said:This insulating tape will cure into a single mass (once applied) to help seal and waterproof cable, wires or even pipes. The tape has good corona resisting properties and can be used on high voltage cables.
You can only wrap it in a spiral, it's not self-adhesive tape.Cheers.
Can probably layer side by side for larger areas.
Oh. Good to know.You can only wrap it in a spiral, it's not self-adhesive tape.
Do you mean 3m 2228..?Where can I easily buy the 50mm 3m rubber mastic tape from these days? Or has the world moved on since then, and there is better stuff. Is element14 the only option? Don't know I need anything else from them, and it's $15 post.
So you can utilise even smaller and more useless bearings. Duh.Why does DUB exist
Buy a bike, buy 5 new tools... what is the problem?Why does DUB exist and why do I need a completely different tool to remove this bb? And does anyone in Canberra have this tool?
Cheers. Yeah that stuff. Checked RS out, but couldn't see it. Ordered from the other place, decided to get 2 rolls to make up postage.Do you mean 3m 2228..?
RS-online perhaps
my patience for these thingsBuy a bike, buy 5 new tools... what is the problem?
The person wanting to modify a carbon Patrol frame could buy these.How many minutes til disaster?
