Pop the outside seals with a pick or Stanley knife (dont dig too deep or you'll snap the end off the knife)No worries thanks. One of the bearings doesn't even turn at all so assuming it's rooted.
I will keep the old one to bash a new one in as you suspect correctly.
The one that doesn't turn might just be caked with dry grease, which could be saved in the short term if it was a major hassle to locate new ones immediately.
Stick a pair of pliers inside the hole of the stiff one and try and turn it while flushing with degreaser, then dry and fill with grease.
Read the number, Hambo it and measure with verniers as said above by @Labcanary and @Dales Cannon to check the right dimensions, thickness, outside diameter and inside hole diameter.
If this is not a long term bike, grab new ones from Ali express. I'm currently running Ali bearings in RaceFace BSA30 BB with no issues.
I got 12 x 6806 2RS for $12 as emergency bearings a while back... probably got 500-700km on 1 set already.
0.76AU $ 87% OFF|Tale Bearing|high Precision 6806-2rs Bearing 30x42x7mm - Abec-1 Thin Section, Rubber Sealed
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
