SummitFever
Pain in the quads is often caused by saddle too low. Pain in your palms could be caused by the wrong sweep on your bars or the bars being too wide or a combo of both.
Saddle position is fine where it is. Legs are good untill I move saddle forward. Moving it forward starts screwing with the knee/pedal position, that what then starts to hurt the quads. Probably more knees than quads.Different pain from riding it when it's low.Pain in the quads is often caused by saddle too low. Pain in your palms could be caused by the wrong sweep on your bars or the bars being too wide or a combo of both.
Not sure I understand the rolling back aspect?Definitely worth trying different bar positions (rolling them back towards you etc)
Shorter stem or higher stem is the other option I guess.
Bar rise won't really bring the bars any closer, but might get you in a more upright position, so less pressure on your palms
You bars should have some lines and numbers in the middle at the front.Not sure I understand the rolling back aspect?
Gotcha. Pretty sure its as flat as it can get now.You bars should have some lines and numbers in the middle at the front.
I used to run my bars rolled forward a fair bit, so the back sweep becomes a bit more up sweep and moves the grips away from you.
Rolling them back a bit so that they are a little "flatter" brings the grips closer to you.
If your after 31.8 stems, I believe the industry 9 30mm and the chromag ranger 31mm look the best. Renthal and pro taper also do a 30mm. Spank split does a 33. There may be other brands but they are the ones I know. I9 probably the cosmetic winner for meSo I'm on an XL bike and I often get pain in my palms when riding. From what my research tells me, the reach could be a tad long.
Was thinking about things I can do to bring the reach in a bit.
Currently have a 35mm one up stem. And the shortest one I can probably get without going a PDent bar/stem combo is to go a renthal 30mm. But that renthal look is not my cup of tea.
What other options do I have to bring the reach in a bit? Would a higher rise help (have 20mm at the moment on the oneup bars). What about sweep? Worth experimenting with that? Are there 30mm stems that look good?
Ideally I'd love to buy one component and be done. Don't want to end up with 3 different bars and a spare stem.
Already tried saddle position. Its slammed back. Any adjustment forward, I start getting pain in the quads/kness after about 1km. So I don't think that's an option and that part feels dialled to me.
Don't forget the seat tube is on an angle. So if you move the saddle forward, you're also effectively lowering it in regards to the relationship between your hips and the bottom bracket. Maybe try moving the saddle forward AND raising the post 1 or 2 mm.Saddle position is fine where it is. Legs are good untill I move saddle forward. Moving it forward starts screwing with the knee/pedal position, that what then starts to hurt the quads. Probably more knees than quads.Different pain from riding it when it's low.
At @Squidface I was chatting with @beeb the other day about mild wrist pain while JRA, and a switch from 12mm risers to 45mm risers seems to have eliminated it entirely. The front end is a little light on really steep sections, but otherwise no drawbacks.@Squidfayce - if you've got any spacers above your stem, try raising your bars - it will slightly relieve the pressure on your hands (it may have other mild effects on the handling obviously, but if it's an option - it's something that costs nothing but a little time to try...)
I feel like the Rotorburn agony aunt at this point.At @Squidface I was chatting with @beeb the other day about mild wrist pain while JRA, and a switch from 12mm risers to 45mm risers seems to have eliminated it entirely. The front end is a little light on really steep sections, but otherwise no drawbacks.
Listen to the good doctor's advice.
Why should I have to think for myself.I feel like the Rotorburn agony aunt at this point.
bar's a 35mm oneup. I think that adds some limitations. turns out the Renthal 30mm legth wont fit the 35mm bar. Best i could find was a raceface 32mm. Will take a look at the others.If your after 31.8 stems, I believe the industry 9 30mm and the chromag ranger 31mm look the best. Renthal and pro taper also do a 30mm. Spank split does a 33. There may be other brands but they are the ones I know. I9 probably the cosmetic winner for me
oh wow...did not even cross my mind. THIS is excellent advice even if it doesn't work. Thanks. I will tray this on the weekend.Don't forget the seat tube is on an angle. So if you move the saddle forward, you're also effectively lowering it in regards to the relationship between your hips and the bottom bracket. Maybe try moving the saddle forward AND raising the post 1 or 2 mm.
It's worth a try to be pain free and you can always put it back.
I have a 5mm spacer then topcap. Can i run without a spacer between the stem and the topcap?@Squidfayce - if you've got any spacers above your stem, try raising your bars - it will slightly relieve the pressure on your hands (it may have other mild effects on the handling obviously, but if it's an option - it's something that costs nothing but a little time to try...)
my thoughts exactly...wait...ARGHWhy should I have to think for myself.
Yes you canI have a 5mm spacer then topcap. Can i run without a spacer between the stem and the topcap?
The bars are looking more the option (of cardy's suggestion isnt the solution). at least that way if i dont like it or it doesnt work, its a component thats not hard to get rid of.
I'll go with a more cautious "sort of".Yes you can
