That's how it starts...I'm all about small splashes of colour here and there, rather than blocks of it, like a whole stem...
I like to make everything clash so that no new/additional clash makes a difference.I'm all about small splashes of colour here and there, rather than blocks of it, like a whole stem.
Rattle-can that f*cker!
Optimal gear display, yay! Are those things removable? Never had to deal with them before.George's have the regular ones in 11:
And some Deore 10sp if it tides you over, not sure if you lose double shifts?
First thing to rip off whenever I've bought a shifter, on the XT ones anywayOptimal gear display, yay! Are those things removable? Never had to deal with them before.
Ah, it's bar clamp anyway. Looking for the I-spec version, for now.First thing to rip off whenever I've bought a shifter, on the XT ones anyway
Yeah I've got a bunch of them sitting in the spares box waiting for a wtb that will never come.You can remove those displays without needing a new coverplate or something similar?
Given your luck with this build you'll be the first person to ever buy a new shifter that comes without either the cover plate or the shift indicator...Ah, it's bar clamp anyway. Looking for the I-spec version, for now.
Given that going to 11sp will likely cost around $350+, I might just replace the old shifter and stick with 10sp a while longer.Given your luck with this build you'll be the first person to ever buy a new shifter that comes without either the cover plate or the shift indicator...
Are you just looking to replace the shifter, or really looking to move to 11 or 12 speed?
Heads up…11sp deore to XT is discontinued. They’re replacing it with lead weight ebike 11sp. It’s not cross compatible with current 11sp.Considering going to 11sp, Shimano M8000 (as long as the mount fits with my M8100 brakes, not sure yet), but finding a shifter in stock is proving difficult.
Lead’s a terrible choice, it won’t be at all durable.Heads up…11sp deore to XT is discontinued. They’re replacing it with lead weight ebike 11sp. It’s not cross compatible with current 11sp.
I’ve bought up on derailleurs.
But, but it’s e-specLead’s a terrible choice, it won’t be at all durable.
Ah, under-engineered and overpriced. Gotcha.But, but it’s e-spec
And overweight.Ah, under-engineered and overpriced. Gotcha.
eBike rider, it’s implied.And overweight.
I meant the weight of the E-components, but ok.eBike rider, it’s implied.
[EDIT] Okay, well probably not miss Q.
