As usual, I couldn't help myself and my brother and I started a tear down. Found a few exhaust and vacuum leaks, changed all the fluids, and now we are stripping the carbs cause they don't appear too happy. Hopefully going to balance them as well. Also considering checking valve clearances cause I don't want to throw a valve at 20k rpm.
I'll load up some pictures later cause right now rotorburn is being recalcitrant and for some reason uploads won't work
Also, digging the two zx's posted. Did you guys do any performance work to them that yielded tangible benefits?
Hahhhhh,yup that was me giving it a lil for my girls riding in the back.....some Sundays you just gotta give a big donk sum :first:I saw a two tone green/white kombi ute thingy hooking it around a corner through an intersection and then fanging it down Sandgate Rd today.
Was it you?
Was very tidy.
Wasn't really planning on doing anything apart from make it run, set it up right and add some sticky rubber. The question was more in terms of "are there any glaring flaws that I can easily correct?". Mum and dad are already eyeing it off and it is likely that in a years time when I upgrade, they will buy it off me. Dad has a thing for small bikes that handle well, and the bike is pretty much exactly what mum wants in a bike. So I don't mind doing the work to it up front as it will get more than just the standard "1 year of use then flog it off" treatment many learner bikes det.Honestly I wouldn't bother upgrading a ZX2R (unless you go for some sticky tyres). You best upgrade is going to be to sell it and buy a bigger displacement bike when your ready.
Most bikes will benefit (post rego inspection) from opening up the airbox (often as simple as removing a restrictor from the aibox inlet), a freer breathing exhaust and a jet kit to suit. Done right it will make more power everywhere and remove the dip in performance at the engine speed at which noise tests are done."Are there any glaring flaws that I can easily correct?"
Good stuff. I just happened to be up that way at my brother in laws and I spotted it when sitting at the lights and though fark that looks familiar!Hahhhhh,yup that was me giving it a lil for my girls riding in the back.....some Sundays you just gotta give a big donk sum :first:
now this looks like fun, didnt want to go Honda K series?Been consuming a bit myself of late.
1zz coming out.
~snip~
2zz in and waiting for some bits.
~snip~
Should be about a 40kw increase in peak HP.
2zz is too easy, was factory option so no compliance hassles. Factory ecu and emissions so no problems. Honda conversions are great but can be troublesome if you try and do it all by the book. Couldn't afford to pay for an engineered Honda conversion.now this looks like fun, didnt want to go Honda K series?
Fair enough. Seems compliance is quite a bit more difficult than in QLD. I just had to get a modification plate for my car (civic with engine/trans swap, brake swap, cage etc etc) and it was as simple as taking it to an engineer for a look over, paid him <$100, and left with a 'legal' car.2zz is too easy, was factory option so no compliance hassles. Factory ecu and emissions so no problems. Honda conversions are great but can be troublesome if you try and do it all by the book. Couldn't afford to pay for an engineered Honda conversion.
Very nice,Bit of a bump. I'm back in an sti.
Forgive me if you've thought of this already ... but if that condensation is from water getting in from outside the unit, it would be a good idea to solve that problem before your fancy new double DIN touch screen unit goes in yeah?... that gets condensation in it and skips like a bitch until the car is warm (takes like 20 minutes or more).
