Funny to see the yellow sea of planes come alive as daylight arrives and fades.
I found it darkly funny...Depressing.
Ep 25 - Too hot to deny - Media Watch
Global heat records greeted with ridicule by News Corp commentators.www.abc.net.au
It was both funny and depressing...I found it darkly funny...
Last night's War on Waste was pretty good. Interesting seeing inside some recycling centres.
But how will they charge their 212kWh EV Hummers?Radio this morning had a discussion on the electrification of ACT.
People reckon they have to go 3 phase for heating and cooling, that just means their house is too big and/or inefficient. If your house is indeed that big, you have enough money to do what is required so stump up FFS. Also switching out water heating to heat pump will reduce that to about 1/6th of a storage system, which gives a bunch back for a hungry air con.
Sick of people making excuses. There really are no valid excuses anymore.
Jetblack did make a smart trainer that was self powered through user effort but it suffered from not having an internal battery storage to buffer and/or the average purchaser didn't generate enough currentHook it up to the stationary trainer and get pedalling!
@Ackland will have his recharged in about 30 minutes, I'd be done sometime around Christmas.
You need an E-Trainer that powers itself!Jetblack did make a smart trainer that was self powered through user effort but it suffered from not having an internal battery storage to buffer and/or the average purchaser didn't generate enough current
Oooh bit of an exaggeration for the Heat Pump HWS I reckon, after having had one for 16 years in SE Qld it's usage is about 1/3 to 1/4 of a storage system. In Canberra that's going to be less efficient.Radio this morning had a discussion on the electrification of ACT.
Ignorance is expensive.Radio this morning had a discussion on the electrification of ACT.
I'm pretty sure you do have to. I'm not trying to piss on your camp fire, but...like when it is cold I want to be able to walk around my house dressed for summer. I can't do that if all the rooms are not churning the aircon to a luscious tropical temperature.Justification was on the hottest/coldest day with all rooms on this capacity would be required. Yeah right gotta do that.
Nope. It's another type of stored HWS. Just one that is more efficient in terms of the amount of energy used to heat the water. Ours runs each day between noon and 2 pm and heats the stored 220 litres up to temperature in about 40 minutes, typically. Only on a 15 amp circuit too.Is a heat pump got water system similar in concept to an instant gas hot water system? Hot water systems aren't something that I have spent much time caring about.
So after 2...it just uses whatever it heated in the middle of the day? Or you guys only use hot water in that window?Nope. It's another type of stored HWS. Just one that is more efficient in terms of the amount of energy used to heat the water. Ours runs each day between noon and 2 pm and heats the stored 220 litres up to temperature in about 40 minutes, typically. Only on a 15 amp circuit too.
