270+ks on it WITHOUT a rebuild.. ie. WITHOUT replacing the seals (or "caps").
EDIT: i have also seen piston engines with more that 500k on them.. i have also seen engines with less than 100k pop. it depends on construction, how strong the block/head is, how it's driven etc etc etc. in the scheme of things 500k is fairly remarkable
yes i know people have crapped on 200kw, but how many 1.3l piston engines are there with 700+kw? my 200kw example is only my own car, and it's pretty much standard.
as with any motor the equation is more power & more mods = less reliability and worse fuel consumption.
i'll say it again, cc for cc, NOTHING.. NO motor will match the rotary.
EDIT: read up, stupid on the fuel efficiency thing. 400kays from a tank is no bad thing
400/55 = 7.27km/L. That's not impressive at all, Landcruisers will get nearly that if they're not thrashed or sat in traffic all day, and virtually every modern 3-4L v6 will do as well or better. If you're really impressed by a "mere 1.3L" engine drinking more fuel than a 4L v6 then your idea of fuel efficiency is not the same as mine. And as Oddjob says, 3 combustion chambers per revolution = effectively a 3.9L engine. Even if it's only counted as double for competition purposes, that's still a 2.6L engine and I don't mean to bag your car, but 200kw out of a 2.6L turbo just isn't that impressive. Especially not when it's been exceeded by 50% by GENUINE 1.3L turbo'd engines. How many do it? Not many, because most 1.3L engines are in motorbikes and thus not turbocharged. And even then, they're edging 150kW (ZX-14 is about 147 or 148) with no forced induction, right off the showroom floor.
And like you say, going by single examples is pretty useless - 270k on ONE car without a rebuild means nothing unless you count the ones that need it every 50k as well. Sure some piston engines blow up under 100k, but realistically a pretty large percentage of them crack 300 without too many serious dramas. Very rare with rotaries.
So, in conclusion:
- cc for cc, yes, piston engines can match The Rotor.
- counting cc for cc is misleading by a factor of at least two and realistically 3
- rotaries are quite heavy on fuel due to their apparent thermodynamic inefficiency (obviously if they have 3x the swept volume per revolution but are only counted as twice the capacity for race purposes, then they're not doing a good job of converting the extra fuel consumption into power at the wheels)
Thus I agree: rotaries are clearly better than piston engines. You could have at least tried to argue power to weight or something...
