leitch
Feelin' a bit rrranty
Enough reason to steer clear right thereDT Swiss CX rays
If it all goes wrong and my brakes explode I will go the f-wits thread.This looks like a well chosen battle. Onward to victory....................
How's the hub?
They work great except for cross windsEnough reason to steer clear right there
Ahah I meant CX Rays are Sapim… if they’re advertised as DT Swiss, odds are they’re not genuine.They work great except for cross winds
The emergency brake of left foot on rear tyre will keep you out of the f-wits threadIf it all goes wrong and my brakes explode I will go the f-wits thread.
I've just ordered the same, thanks for being the crash test dummyMy bleed kit arrived today. Looks good for $18 be a while before I need to use it but better than nearly $100 for the Hayes kit.
Well I'm a chump for buying the exact same kit from MTB Direct a couple of years ago. Actually...I think it cost me about $15 at the time.I've just ordered the same, thanks for being the crash test dummy
There is different versions. Just had a look and they have for the for $32-40 so you grabbbed bargainWell I'm a chump for buying the exact same kit from MTB Direct a couple of years ago. Actually...I think it cost me about $15 at the time.
I rate it for use with Shimano and Magura.
Just make sure you get the higher end version as the cheap ones have plastic fittings vs metal.I've just ordered the same, thanks for being the crash test dummy
Cool. It's the one with metal fittings so a score indeed. I must have got it on special or it was pre-Covid pricingThere is different versions. Just had a look and they have for the for $32-40 so you grabbbed bargain
Great so far after about 60kms. If it keeps working like this its a winner.How's the hub?
I got the same kit a few months back !My bleed kit arrived today. Looks good for $18 be a while before I need to use it but better than nearly $100 for the Hayes kit.
Fittings for formula?I got the same kit a few months back !
Mine is the $12 kit... decent syringes.
19.07AU $ |Bike Tool Kit Hydraulic Brake Bleed | Bleeding Kit Disc Brakes Ezmtb - Bicycle - Aliexpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Should do. The kit I bought comes with a bag of various metal fittings and they list formula in the description.Fittings for formula?
Haven't tried it yet but apparently so.Fittings for formula?
Thanks, hadn't ordered anything in a couple of weeks and needed to scratch that itch.Also taped up the new DT350/511 wheelset with this tape. Would recommend, sticks well and seems pretty tough. Much better than the Bear outdoor masking tape.
0.75AU $ 90% OFF|Tensilized Strapping Tape For Bicycle Tubeless Rim 9.14m 23/25/27/29/32/34mm Evenly Adhere For Long Lasting Hold Less Residue - Bicycle Tires - AliExpress
