If you put an elliptical ring on an orange is it still shitrus?
I've got the address for a bloke in Buninyong...I was thinking about doing a review of mtn bike specific padded underwear. Once I've put the review up for appraisal just send me a PM from the next member in-line to review the undies & I'll mail 'em on to you....
Mandarin...If you put an elliptical ring on an orange is it still shitrus?
What did Stoo do to deserve that?I've got the address for a bloke in Buninyong...
Nothing. Amusement is so hard to find in these modern times... sometimes it takes a low blow to extract even a smidgen...What did Stoo do to deserve that?
Well until I was pointed to Rotorburn , I usually took a gamble on things . Some worked some didn`t , part of the learning process , I guess , but expensive . So when I`m looking for product I generally search Rotorburn pretty hard to see if someone else has used it and what they thought which I see as , and I`ll term it like this for want of better words , " real people " have used it and it performed good / bad and that influences my decision on a product . Dozers review on this will make me try one cause I know he is all about the down so if he says it made him climb easier then thats good enough for me .Not just aimed at Swaz but what pattern do you use for buying parts if you think all reviews on websites are total load of bullshit?
He'll deny it was ever given to him and / or used.Next reviewer: Bermshot please
Maybe he wrote this review, ironically of course.He'll deny it was ever given to him and / or used.
Why is going to ride him a d post the review? Not me.Next reviewer: Bermshot please
Wait....what?? Not me.Why is going to ride him a d post the review
"the tin foil hat fit snuggly to my helmet and stayed in position through some very rough terrain. Well done al-foil."
All this and more tonight at 7.Wait....what?
I have a One Up Components oval ring on my XT cranks.Hers a little tid bit of info regarding these particular rings.. as they are threaded, they are not compatible with any crank spiders that the screw is installed from the rear or inside on, such as my M8000 xt's. From the front or outside, they simply do away with those pesky threaded inserts, but the other way around and you won't be able to use a threaded ring as you can't pass through 2 threads and pinch it up tight. Which makes this particular brand incompatible. I did do a quick search but couldn't find a slip through option, happy to be proven wrong though...
Is the ring itself threaded?I have a One Up Components oval ring on my XT cranks.
Oh, not sure I'd have to check. I misread you; thought you weren't sure if there was an oval option for XT.Is the ring itself threaded?
Usually only 32T and below that are threaded, at least for symetrical BCD.Is the ring itself threaded?
Interesting. I'd never seen a threaded ring before this one.Usually only 32T and below that are threaded, at least for symetrical BCD.
My ring has been threaded for ages, surprised you didn't notice...Interesting. I'd never seen a threaded ring before this one.
