Raf: 8 minute?? That's VO2 teritory
The closest accepted definition for aerobic threshold is "A term sometimes used by sports coaches and trainers to describe a level of exercise somewhat below the anaerobic threshold. It, however, is not a defined physiological term. The AeT is sometimes defined as the exercise intensity at which anaerobic energy pathways start to operate and where blood lactate reaches a concentration of 2 mmol/litre (at rest it is around 1). This tends to be at a heartrate of approximately 20-40 bpm less than the anaerobic threshold and correlates with about 65% of the maximum heart rate".
65% - That's not even base HR! I agree, I have never heard of that term.
As mentioned above, the problem with Raf's no.s is the difference between his 8min & 20min HR's.Bear,
The 158 HR that RAF is talking is the highest average for 2 8 minute runs.
I have also completed the two runs using the same information as RAF and mine is not much different to his.
I am no fitness instructor or sports scienctist so I cannot confirm that this is correct, but my sister is a personal trainer. She worked out my maxium HR at Anerobic Threshold and it was 5 bpm diffferent to the CST field test that RAF and I camoplete. My highest maximum for this test was 178.
I feel that with her input and the science provide in the book, I am comfortable with calculating my training zones using 158 as my max just likeRAF unless you can provide another alternative to this.
Everybody has their own was a looking at something and if the science works for me than that is what I go with. So far its working in my lead up rides. I have removed almost 4 mins of my average around my local just by using this information, and that is even before I start the traing program.
Daniel
that's correct. Don't compare!!As mentioned above, the problem with Raf's no.s is the difference between his 8min & 20min HR's.
20 minutes sits well within your aerobic capacity, 8min efforts are hitting the top end.
I am only suggesting he re-test because of this. IMO he hasn't pushed hard enough.
Also you shouldn't be comparing your numbers to someone elses!
As an example my 20min is 156bpm but 8 minutes is 183bpm, but I haven't given you my age, training history (acute & chronic load) etc
I have to give you the uneducated answer here.... sorry, I just dont know enough but I will try and give you as much info as I can....If you can hold 156 for 20min, they why only 158 for 8?
Wind trainer is really hard to get and keep the HR up. Outside will definitely raise it.I appreciate you helping me understand this Bear, and Im taking it all in.
In regards to my test, I did it indoors on a wind trainer, and yes, I probably could have gone harder, at least a little, but I just couldnt maintain the power at a HR above 160 and that being said I nearly fell off the trainer at the end of the second one. Both tests resulted in the same HR measurement, 158.
If this is your Anaerobic Threshold (aka Lactate Threshold or defllection point) then it really does hurt.It seems this threshold really does hurt me.
I would almost go so far as to say that your LT may be around the 156-158 mark, (my experience is that climbing HR is very close to LT) but what concerns me is that you can do it over 5.5 hours.Since learning that the Jet Black lap involved a 100m climb over 2km firetrail, I have been doing fire trail Hill Reps. From the car park I climb up via blue gums firetrail, to the bobby pin junction, turn right and climb the fire trail along Cardiac climb, then hairpin left climbing up to the top of ABC and onto the road for the climb to the obsewrvatory. I truly cant remeber how long that takes, (Tegski might rememebr from our last seesion) probably 20 minutes?
During that climb, I can maintain 156 - 158 for the whole climb, with the odd spike into the 160s. Its actually a challenge to keep it under that. Note that it is my training intention to maintain that rate, so not necesarily the result of the effort if that makes sense. I have done 7 reps of that climb back to back, over 5.5 hours. So it is maintainable.
However, whenever I have tried to "Smash the climb", I cannot get further than 1/3 up cardiac fire trail before I have to sit back down and 'drive miss daisy' for a while. Then I get into a rollercoaster of between 168 down to 154 etc.
Yep my bad, I was thinking anaerobic threshold not aerobic.wolfjjj: What you are describing is anaerobic threshold/ lactic threshold/ OBLA. The lactate threshold (LT) is the exercise intensity at which lactic acid starts to accumulate in the blood stream. (This is not strictly true, as 'lactic acid' per se does not exist at the pH-levels encountered in the body. Its anion, the lactate molecule, accumulates in the blood—hence its usage in 'onset of blood lactate accumulation' (OBLA) is 'lactate' and not 'lactic acid.'
When exercising below the LT intensity any lactate produced by the muscles is removed by the body without it building up.
Although the lactate threshold is defined as the point when lactic acid starts to accumulate, some testers approximate this by using the point at which lactate reaches a concentration of 4 mM (at rest it is around 1 mM).
For clarification, this includes skyline / luge decent and a meander across country in between reps. I cant hold 156 for 5.5 hours.I would almost go so far as to say that your LT may be around the 156-158 mark, (my experience is that climbing HR is very close to LT) but what concerns me is that you can do it over 5.5 hours.
Shouldn't be a problem, just make sure you get a good warm up on the way thereOk, I will go do it now for lunch. I will do stromlo road x two climbs, with a 10 minute break in between.
I can only measure heart rate, and it will be on the MTB, is this ok?
Raf
It is such a fine line between sustainable and blowing up and it getting messy! I do believe that small gains can be made - ie raising the ceiling on your LT. It is quite well know that the anaerobic capacity and LT ratio are linked. Therefore if you work on your anaerobic ability and raise that capability, then your LT will also rise.All this talk of 8 min HR test has me interested. I've been reading Heartzones recently and starting to put that into practice but haven't done that many of the assessment tests yet, tough part for me is just finding a good spot to test it where I won't get stopped by cars/traffic lights. Hills are fine but most are too short and the downhills allow my HR to drop.
I had a look through some of my most recent race data and it seems like my LT is around or slightly above 170 on the bike, and I can sit at 170 or just below for around an hour at a time (or for a long lap of an enduro) going all out. I can get up into the high 180's but anything above 170ish hurts and I blowup pretty quick and need time to recover.
Max HR on the bike is high 180's, I get to 187 fairly often on all out hill climbs but I've never cracked 190. Running though I can crack 190 without too many problems but that is usually higher than for cycling in general.
