AliExpress have knock off fidlock bottles. As long as it doesn't get squashed in transit they are ok. I bought one to test out, it was great so bought another, but the second one had a damaged bottle on arrival (no padding, it was loose in a post bag). So I ended up with two mounts and one bottle to use. Which isn't so bad for a second bike I suppose.Oranges have the bottle slung underneath… Recommendations for a cage that will work upside down and not lose the bottle?
The Orange Facebook peeps reckon a fidlock is the go, but 90 bucks feels like a lot for a water bottle…
Have lost a couple of Fabric bottles, switched to Fidlock and never looked back. Fidlock underneath would have the added advantage of not smashing your cage if you 50:50 something.Or fabric cageless:
Fabric Cageless Bike Bicycle Water Bottle 600ml
Think outside the cage Challenge convention with Fabric's cutting-edge cageless bottle. Do away with bulky cages and keep your bike lightweight and clutter-free.www.dysonbikes.com.au
Good to know re: fabric bottles.Have lost a couple of Fabric bottles, switched to Fidlock and never looked back. Fidlock underneath would have the added advantage of not smashing your cage if you 50:50 something.
Jesus - is that a camelbak bum bag….? Hard pass…Water bottles under the DT are the worst. Just get one of the Camelbak bottle holsters like the Podium Flow or Flash belt @Haakon and carry a bottle that way.
Not that I'm offering to test the theory but I think that an impact like that on Fidlock would just flick the bottle from the mount and presumably you'd notice in time to pick it up. Conversely I have been on bike packing trip where a friend smashed his downtube mounted cage going over a log and then we had to MacGyver something up to carry the bottle for the rest of the trip.Good to know re: fabric bottles.
I'm not sure one would want to smash a fidlock bottle, given how much they cost!
Having said that, I had a cage and bottle on the down tube of my Spitfire. It was shit. I ended up taking it off and either not carrying water (short rides), or taking a backpack with water (longer rides)
This was my issue with under frame bottles. The sucky bit would get filthy. Maybe I should ride more salubrious locations?I used to use a normal King Cage on the bottom of the downtube when I took a second (camelbak brand) bottle on a long ride. Worked fine and never lost one or noticed any issues with it. I did always swap the lid over with the ‘clean’ bottle from inside the frame triangle as the lower one would cop some crud.
Footpath?This was my issue with under frame bottles. The sucky bit would get filthy. Maybe I should ride more salubrious locations?
WRONG thread...I had a big old trailside rant at the stupid Fidlock bottle I'd lost on a longish ride. What a waste of all that money.
Until I returned home to find it sitting, filled to the brim, on the kitchen bench...
I wasn't aware they had a return to home feature like a drone, that's probably why they're expensive.I had a big old trailside rant at the stupid Fidlock bottle I'd lost on a longish ride. What a waste of all that money. Dumb, flawed design.
I've had to stop and find a lost Fabric bottle too. They just didn't hang on well enough for me.Both times I lost Fabric bottles were just rough descents and I didn't notice they were gone until I reached the bottom.
Spesh Zee cages are pretty sturdyMaybe a side loading bidon is worth a look?
yeah nah, something like the topeak versamount bottle cage mounts $15 at the wiggles, might do the trick. what's the diam of the tube you want to mount a cage on?Oranges have the bottle slung underneath… Recommendations for a cage that will work upside down and not lose the bottle?
It has conventional mounting bolts under the down tube - thats just where they are on the Oranges...yeah nah, something like the topeak versamount bottle cage mounts $15 at the wiggles, might do the trick. what's the diam of the tube you want to mount a cage on?
found this article:
Ways to Attach Water Bottles and Add Cage Mounts to Your Bike
How to add cage mounts and attach water bottles to your bike using commercially available options and DIY solutions, or move them to accommodate other gear.bikepacking.com
also BBB HaulerMount,
& SKS anywhere
This Zefal one "Zefal Gizmo" uses zipties, so it might be the best bet. (a bit of plumber's tape would help secure them to the tube to stop it slipping or marking the tube)
Zefal Gizmo Universal
The Zefal Gizmo Universal bottle cage mount allows you to mount a bottle cage on a bike without the frame bolts for a bidon cage.www.abbotsfordcycles.com.auZefal Gizmo Universal Bottle Cage Mounting Kit
Buy Zefal Gizmo Universal Bottle Cage Mounting Kit Now at Pushys. Lowest Price, Secure Shopping and Fast Delivery from Australia's Best Online Bike Storewww.pushys.com.au
as long as you are happy putting a bottle there, then all good.It has conventional mounting bolts under the down tube - thats just where they are on the Oranges...
