birddog69
"Most recent Google review is worrying..." 'nuff said. Thanks.Most recent Google review is worrying...
Yep did that twice lol3. Get a 2 syringe bleed kit and do the back and forth bleed. Shimano brakes tend to keep bubbles in the master cylinder and you can flick the lever a million times to get the out with the cup, but two syringes is way better.
In that case check 1 and 2. The ceramic pistons crack just by thinking about them.Yep did that twice lol
SLX don't have stroke adjust; the reach adjust knob only moves the lever blade but doesn't alter stroke.Quick question (easy one for the seasoned folks):
Shimano SLX brakes bled to death and the bite point is ridiculously low, almost at the bar. Tried everything from new pads, pry apart, clean pistons, bled both ways twice. Still the same. Works but just the bit is ridiculously low. Yes I have checked the adjusters too. I took the wheel and rotor off and tried to clamp the pads together and they didn't actually meet. Are they on the way out, or is there an easy fix?
Did you fit it with a soapy spray that gives you time to adjust it?I use this helicopter tape. https://www.ebay.com.au/itm/3249905...xNkuRf0OSJ2&var=&widget_ver=artemis&media=SMS
Thanks, I need the spray application type. I have fitted Invisiframe twice and it is inevitable that you will get bubbles or it is off centre, etc.I used a 3M tape as well. Just spray sticky side with water with a very small amount of detergent in it. It will not start to stick until you wipe over it with a credit card or similar to squeeze out the water. Even then you can still peel it off and reposition for 15 minutes or so. This should work with pretty much any type of clear adhesive tape.
Check clearance on the passive side first. Screw the pad in until it just touches the rotor when the wheel is spinning and then back one notch/flat. Then adjust the cable to suit your preferred bite point. I used to make the two pads about the same.Tektro cable disc brakes: Is it just a case of pulling the wire tighter to get an earlier bite point (lever is currently going to the bar without a lot happening) similar to cable brakes of old?
Youngster's brakes are very iffy and I suddenly realised it's been a while since I've had to adjust cable brakes!
Usually with mech disc brakes only one side pulls in, the other side stays static. So you'll need to get the static side as close to the rotor as possible without rubbing, then adjust your cable tension. The static side should also have a pad adjustment screw that you can turn to get the pad to move in closer to the rotor as the pad wears.Tektro cable disc brakes: Is it just a case of pulling the wire tighter to get an earlier bite point (lever is currently going to the bar without a lot happening) similar to cable brakes of old?
Pretty sure your 230x65 is the same as the 230x60 just without a 5mm travel spacer/reducer.My current rear air shock is 230x65 but I found a awesome deal for a spring shock but it’s 230x60 will it fit? What’s pros cons?
Cheers in advance
Gave these guys a try. Pricing is reasonable for a partial frame skin.It is PITA to fit and takes longer but knowing that I won't get it right first go makes it the better option.
I had no problems using these (shimano though) on the kids bikes and the Minister for War had BB7s for a good while. Hydraulics had too much bite and grip for light weights. Upgraded as they got bigger and faster. Wife has hydro Deores now but she struggled for a while with the change from rim brakes to discs and the transiti9n through cable discs was helpful.The best mechanical tip I can give you for mechanical discs is to get your hex keys out and remove them. Then replace them with hydraulic discs. If price is a concern, just use some cheap Shimano or tektro ones. They will be infinitely better than the cables and prove less frustrating.
He's going to grow out of the bike in the next 18 months so upgrades aren't a priority at all.The best mechanical tip I can give you for mechanical discs is to get your hex keys out and remove them. Then replace them with hydraulic discs. If price is a concern, just use some cheap Shimano or tektro ones. They will be infinitely better than the cables and prove less frustrating.
