Yeah nah. You have bigger issues to deal with than that.And cranks that aren't near the ground
it pedals surprisingly well, the cranks are longer than what was speced thoughTo be fair to the bike if it came with cranks welded parallel to the ground it would probably still fulfil its design brief of gunning downhill jumping. Pedalling was never considered for these was it?
175 spec’d on L/XL. My mates new L came with 175. No issue with pedal strikes.it pedals surprisingly well, the cranks are longer than what was speced though
nuff said170mm are acceptable.
If you don’t have 165’s.
I do have one bike still running 175. I do notice it, and I don’t like it, but horses for courses.
Not really. It’s not pedal strikes, or the lack of, that are my problem.nuff said
I’ve got pedals, but I’m putting on some cheap metal Wellgos until I have shorter cranksI've got some unused dmr vaults...but maybe figure out the crank issue first.
Given your track record that probably isn't a bad idea.I’ve got pedals, but I’m putting on some cheap metal Wellgos until I have shorter cranks
Are you getting less pedal strikes with the 170's?A bit late of an update, but I figured out why it was skipping gears View attachment 395939
The barrel adjuster assembly had snapped off... This is already the second warranty shifter for me
So now it’s got a deore shifter and mech and an nx cassette. Now also has a pair of 170mm cranks from @Labcanary.
Now I just need to figure out what’s happening with the rear brake, and then it will be at a point that I’m happy with it
Yep, the 170s give me much less pedal strikes, 165s would be better again.Are you getting less pedal strikes with the 170's?
What's the brake you're using and what is it doing? One of the brake gurus might be able to point you in the right direction for a fix.
Yep, your troubleshooting skills are on pointYep, the 170s give me much less pedal strikes, 165s would be better again.
The rear brake just seems to be leaking, I think I might not have seal them up properly
You will be able to superglue that back in place till you get a replacement.The barrel adjuster assembly had snapped off...
That was a microshift acolyte shifter. I have xt m775s brakes and I hadn’t sealed an olive right. Seems to have held up to the last couple of days at Derby/ St. Helens all goodCrap-end SPAM shifter; seen shitloads of them break off the adjuster nub like that.
"Leaking brake" isn't a particularly precise description. Can you please be a bit more specific as to where it appears to be leaking? Also to repeat part of @Labcanary's questioning, what brake?
