blacksp20
I own a 2011 Yeti 575 and have been fairly happy with it except for pedal bob and mid travel support. I have had the factory RP23 tuned by Avalanche to get more compression damping at the expense of propedal, which I've never found to work properly even after servicing. Since the tune it's good for jumps and small drops but it still bobs under pedalling and wallows in the midrange unless I put extra air pressure in, but that messes up the small bump compliance.
I am a clyde at 115kg and I usually run 260psi for about 25-30% sag. Now I've scoured the Yeti forums on MTBR but most 575 riders haven't messed around with their shocks and the rest have move on to other frame designs.
I've found a leverage curve which shows a regressive to progressive line through the travel.
http://m.vitalmtb.com/photos/featur...ti-SB-66-Leverage-Ratio-Curve,21268/sspomer,2
From what I can gather, a coil would be terrible for this style of suspension. Cane Creek shocks don't fit, I'm guessing due to the dogbone. I investigated the larger volume air cans but realised that I would have to increase air pressure by 20-30% from the reports of other users with them, which would put me past the safe useable pressure of the can.
Can anyone suggest a shock that could work with my frame? I've been looking at Monarch+ but I'm not sure if the claimed mid support they have would be enough for me.
Your suggestions would be greatly appreciated.
