Removed by user
No lsc/hsc? Sounds like an old school Marzocchi.No issues, it's a really simple design open bath damper with a needle style damper adjust the flow rate, then just using different oil weights and viscosity will fine tune it.
Super easy install as well, and a massive range of adjustment on the dials. fully turned in rebound almost keeps the fork locked down, and wound out will result in a reasonable top out clunk. It's also back to front, the rebound control is at the top of the fork, and compression is underneath the lower leg.
