Let's wait till I've safely anodised it before we call it a win. I guess it has to be purple so it's lighter?Impressive job, there mate!
top cap to csu | 26.5 | 1.8 | |
brain adjuster | 19 | 1.5 | |
top cap top damping rod | 6 | 1 | |
rebound adjuster | 2.9 | 1.78 | |
damping body top and bottom | 16.5 | 2 | |
brain to inside of IFP body | 20 | 1 | |
IFP to upper body of brain | 21 | 1.5 | |
IFP | 17 | 3 | |
IFP body to existing lower fitting | 21 | 1.5 | |
IFP chamber bottom to hollow rod | 10 | 1.5 |
I really need this..do you have pict to show?tksWow I'm sorry I missed this, never got the push notification, hope I'm not too late.
To remove the hose from both ends you need to compress the wire c clip. It is a bastard to do. You need two small pins to push into the holes on either side. But before you start, you need to spin the c clip in position till the opening is at the 6 or 12 o'clock positions so it compresses easily.
The first time I tried, it took me an hour to get one c clip out. As for pins, I found sewing machine needles cut down worked.
Do NOT scratch the inner surface, this is a sealing face.
I've sent you a pm, hopefully you get it.I really need this..do you have pict to show?tks
Sent from my SM-G7102 using Tapatalk
Link , is all this relative or just isolated to Specialized ? Although I think answering my own question its all a mix ? X fusion fox specialized with a bit of RS mixed in ? Either way admiring your resolve .
From what I know in the last two years there was an admit by Specialized , not public , that there was a problem with the forks . All components went back and were all replaced with complete RS hardware .Latest generation Epic's (2014 till now), use Rockshox forks with Specialized's own brain cartridge. Rear shock is fox. Same inertia valve in both assemblies ( with different shim stack configs) so I'm guessing Specialized is making the custom parts themselves.
Hoses for rear shocks have never changed from what I've seen ( apart from shape at shock end)
In parallel to this project, I have the somewhat dormant Frankenfork project. Just need to finish the brain fork cartridge rebuild first. Plan b might be modifying a cartridge leg rod and adding an external Schrader valve for now, but want to be able to move cartridges between RS Sid and Frankenfork.
Interesting. I did ponder if the reason for such super secret squirrel business was a silent mass Warranty exchange program.From what I know in the last two years there was an admit by Specialized , not public , that there was a problem with the forks . All components went back and were all replaced with complete RS hardware .
Limited to pros .Interesting. I did ponder if the reason for such super secret squirrel business was a silent mass Warranty exchange program.
I've had a few PMs from people on the inside, no mention of this.
It would be easier getting Moorey to eat red meat then getting commercially confidential info like this from people.Limited to pros .
