hifiandmtb
Sphincter beanie
Awesome work!
Awesome work!
Yep. With the brain fade threshold on 6, with IFP at 120 psi, it's too stiff. Going to experiment with pressures next ride.Too stiff as in it needs too big an impact to unlock?
What air spring pressures?Yep. With the brain fade threshold on 6, with IFP at 120 psi, it's too stiff. Going to experiment with pressures next ride.
90pos, 110neg. Same as always.What air spring pressures?
No no, I've rebuilt about 5. These shops have rebuilt in excess of 30.Have you rebuilt over two dozen rear Brains?! Congrats Linky - what a champion! Great to see all your good work making a difference.
Specialized already have their parents covering the inertia mass, valid even here is Aus. I've not sold anything, all of my work has been for free so I can gain further experience. Plus the patents do not specify o ring sizes, shim stack dimensions or oil viscosity, so these are not protected by the patents. (Would have saved a lot of time if they did)Awesome work Link . Time to apply for a patent before the big S come knocking with their lawyers ? Out of interest have you all shared IFP pressure rates and come to a common ground ? Maybe the brain is reacting ?
Very impressive . I remember ferrofluid from way back and just had a google to catch up with what they are now doing . Wow .Specialized already have their parents covering the inertia mass, valid even here is Aus. I've not sold anything, all of my work has been for free so I can gain further experience. Plus the patents do not specify o ring sizes, shim stack dimensions or oil viscosity, so these are not protected by the patents. (Would have saved a lot of time if they did)
My current focus is on electronic means. Many short comings of the mechanical system, but electronic systems like ferrofluid based dynamically adjusted viscosity are a mine field, I've got 180ish patents from EU and the USA to read.
IFP pressures, minimum starting point is full depth so it's touching the valve gate above it when shock is at the ZERO travel position, and pressure is set at expected positive air can pressure (at sag position) plus 20psi. This works a lot better then a fixed arbitrary value.
An sworks style race tune is an extra 100psi, so for me that's 280psi. Running schrader valves rated at 800psi now, which allows trail side tuning.
Tuning IFP pressure on the trail side is pretty cool.
That's a pretty cool result. Congrats on working through a problem and including us in the ride...Have now had contact from the fourth suspension shop from around the world who have reached out and thanked me for the results of this project. Two of them I have made them tools (bleed port adapter, shaft clamps, sample Schrader valve stopper)
Over 30 rear brains rebuilt.
Woopieeeeee. That's the ultimate result.
Post up some pics of the offending shock and we'll see if it matches the shock off redbruces' epic of that vintage.Having just spent $350 on a rear brain service for my 2011 SW Epic (fluid leaking into -ve air chamber, main seal leak, no internal pressure and low on oil. IFP topped out), I've come to the conclusion that this is too expensive to maintain commercially.
If you ever want to start making a kit, let me know.
I've picked up a brain damper cartridge from a Stumpy which I want to pull apart - I've got the schematic from Spec which provides a great start.
BTW, a few pages back in this thread there was some comment about catastrophic loss of pressure from the RS dual air spring, the answer is usually to remove the top cap and put some oil down the leg, cycle a few times and then you're good to go. It happened to me and the LBS couldn't figure it out so got me a new fork carbon upper and told me that there was a leak between the carbon crown and the legs (which would defy physics if it did happen). Bikie was under warranty and one of the uppers had a scratch so I wasn't sweating it. The the fix is really easy.
Once again, great read thanks.
