link1896
Mr Greenfield
I'd just machine a "dimple" on the inside of the air can at the point where you want equalisation to occur. Measure the dimple position off of one of your air cans that actually has the dimple. Use a dremel etc. with a small (2mm diameter) rotary burr. Give it a good polish afterwards to remove any sharp edges. You will not need much of a "dimple" because of the relatively high pressures involved. If you can, measure the wall thickness of the can so you know how much material you have to play with.
Effectivly this is now a solo air vs dual air debate.
Things that make you go hmmmmm.
As usual summit, thank you for the input.
