気が狂っている男
He lives! Good to see you and the shock live to ride again.
Just giving the shock a service can make it feel like it has less comp damping because of the reduced stiction. Does the brain have some sort of comp damping adjuster? Going to a heavier weight oil is very much like adding clicks on your comp (and reb) adjuster. Heavier oil has almost no difference on damping in high speed events, it really only has an effect on flow through the free bleed circuits and past the shims on very small shim deflections....Compression damping has been reduced, bottomed out over the usual drop offs with the same air pressure in the air Spring ( as set by the auto sag, 220 psi)...
So changing oil weight can be a useful approach where you've run out of clicker adjustment, but a huck to flat can be a fairly high speed damping event that will not be affected much by going heavier on the oil.
Also, even though the IFP pressure does very little to affect the overall spring rate of the shock, reducing the IFP volume or upping the IFP pressure can assist with ramping up the spring rate just before bottom out.
Position | Material | ID | CS |
brain adjust knob | buna 70A | 3.68 | 1.78 |
top outer of reservior can to machined head | buna 70A | 22 | 2 |
IFP | buna 70A | 18 | 3.55 |
nitrogen stopper | buna 70A | 22 | 2 |
brain piston OD | buna 70A | 20 | 1 |
hose end x 2 (polyurethane) | polyurethane | 4.75 | 1.8 |
bearing (black) to damper body | buna 70A | 21.95 | 1.78 |
bearing (bsilver) to damper body | buna 70A | 15 | 1.5 |
bearing to damper shaft seal | ?? | ?? | ?? |
aircan to damper body quad ring | buna 70A | 20 | 3.55 |
metering rod | buna 70A | 2.57 | 1.78 |
aircan to head | buna 70A | 34.5 | 1.8 |
damping rod to head | buna 70A | 10 | 2 |
You are rebuilding red's shock?and o rings for the older X fusion shock, ala redbruces
Be sure to edit the original :heh:
280psi feels like factory fresh WC tuned brain. Still going strong about 14 rides later. Only issue is the o ring to seal the brain fade shaft properly makes adjustment hard, but it's not a regular adjustment.Bad things happen when IFP pressure goes lower then air can pressure. It lets gas into the damping oil, game over
Had to do another bleed, managed to do it with assembly still on bike
Thank you marpilli, welcome to our crazy little forum.Just wanted to drop in and say congrats on the rebuild!
Was directed to this thread from HuckingKitty whilst trying to find info about Brain rebuilds.
Great reading!
I have an s-works Enduro from 2004, and I think the 'brain' has finally gone (loss of the nitrogen I think), the shock itself seems fine (holds air pressure).
I've managed to get a second hand RP3 so that I can have a go at the brain, and this thread is certainly going to help - although I doubt the seals will be the same size! And I don't have the tools to build up a vacuum pump for bleeding, so I'll need to be creative there, but nothing lost, nothing gained!
Once again - good job sir. Out of interest - what is your day job?!?
Jason
position | ID | CS |
brain adjust knob | 5 | 1.5 |
aircan to damper tube quad ring | 20 | 3.5 |
IFP | 17.15 | 3.52 |
nitrogen stopper | 20 | 2 |
brain ass seal | 10.7 | 1.5 |
hose end x 2 (polyurethane) | 4.5 | 1.8 |
metering rod to inside of damper shaft | 3 | 1.5 |
air can to head | 34 | 2 |
damping body to bearing | 19.5 | 2 |
bearing to damping rod (polyurethane) | 12.37 | 2.62 |
IFP fill port | 3 | 1.5 |
bearing to air can | 24.99 | 3.53 |
travel indicator | 20.29 | 1.6 |
travel indicator | 20.1 | 1.6 |
For the life of me I cannot see or feel the negative air equalisation notch in the air sleeve. When we disassembled there was some negative air. I'm as confused as Mike Tyson in a library. Hmmm
Before negative air chamber equalisation notches ( or auto sag), the process of removing and reinstalling the air can recharged the negative chamber. Something we take for granted these days
