Been doing my own for a long time, used NS Dynamics once when I unloaded the CTD grub-screw on a shock and didn't realise it was spring loaded and spun around 360°, the CTD wouldn't work then so I sent it to NSD for a fix and service.
Got oils, seals and all most of the stuff I need but starting to think the googling to find the parts, the worry I have ordered the right stuff (which is too late when you have your fork in bits) isn't worth the hassle for my bikes. I also refuse to buy another seal installation tool for the tight Fox fork seals, already got the 32mm, I'm not really enthused about collecting anymore.
Its no worries with my boys bikes, 40kg each and 50psi in their forks, a seal swap and leg service takes me 20mins so I will continue to do theirs at home.
So what recommendations for a service centre ? NDS, Cyclinic, MTB suspension centre... any others ?
Also, just been reading about some of NSD's upgrades, are any of them worth getting ? Has anyone had that Vorsprung ‘Luftkappe’ upgrade ?
Since getting a little bit more 'trail' orientated, I am starting to appreciate small bump and a greater ramp at the end of the stroke.
The fork is a Fox factory 34 float fit4 and the the shock is a Monarch RT3 debonair.
Cheers
Cheers
