I have 2 complete spans of it at the back of the bike vault, 12 fckn boxes of Xmas decorations.Eeewww, none of that junk is allowed in my shed!
None in the garage
Show some pics. Bit of 50 rhs glued together is quick and easy and solid. Fix a rail to the wall and two feets at the front with some flatbar on the bottom to the concrete. Then cover the top with some timber planking. I like that bunnies stuff, we made #2 a coffee table from it, but it wouldn't survive being a bench top at my place.Seriously, the metal systems are a non starter here, anything with 4 legs. This really has to attach at two points only - wall at the back of the bench top, and legs on the floor at the front.
I think the thing I’m most excited about it having somewhere to mount a proper vice… I’ve been making do without for decades!You guys are Rufus rough guts, you don't bash things with a hammer on a benchtop, you do that on the ground or in a vice.
Some “interesting” choices were made back in the 60s when this was built!!Show some pics. Bit of 50 rhs glued together is quick and easy and solid. Fix a rail to the wall and two feets at the front with some flatbar on the bottom to the concrete. Then cover the top with some timber planking. I like that bunnies stuff, we made #2 a coffee table from it, but it wouldn't survive being a bench top at my place.
My big vice has a flat plate on the back that gets most of the heavy pounding (minds out of the gutter) but an anvil would be betterer, even a small one of 50kg ish.You guys are Rufus rough guts, you don't bash things with a hammer on a benchtop, you do that on the ground or in a vice.
Yes but what is the vice attached to, when you are hammering on it?You guys are Rufus rough guts, you don't bash things with a hammer on a benchtop, you do that on the ground or in a vice.
You can clamp small things in a vice to say knock a bearing out, rather than mark all the top of the bench, the other stuff you can do on the floor with a piece of hardwood timber or with an anvil. I actually have a steel plate bench outside but many on here wouldn't fabricate stuff as I do.Yes but what is the vice attached to, when you are hammering on it?
It's @Haakon pics would be too easy, as it's not a French car.
I'm with @Dales Cannon if four legs is too hard. Mount said vice as close as possible to one of the vertical legs to transfer hammering forces to the ground, job done.
I was mounting the vice on the Renault. No other reason for it to be there surely?Yes but what is the vice attached to, when you are hammering on it?
EDIT, @Haakon I take that back I didn't see your post above. The funky concrete looks like the footing for the wall.
Thinking outside of the box here but could the bench run along the length of the back wall where the Ryobi box is sitting in your photo? I'm assuming that the floor is level in that direction and then the wall with outlet could be shadow board for tool storage and shelves etc. At least this way you aren't standing on an awkward sideways angle while you're working at the bench.Some “interesting” choices were made back in the 60s when this was built!!View attachment 397791
Good idea, but am wanting to create some storage spaces up in the bat cave void.Thinking outside of the box here but could the bench run along the length of the back wall where the Ryobi box is sitting in your photo? I'm assuming that the floor is level in that direction and then the wall with outlet could be shadow board for tool storage and shelves etc. At least this way you aren't standing on an awkward sideways angle while you're working at the bench.
Edit: Like this.
That's fair and I'm probably starting to move well outside the original scope but you could put in a small set of stairs to access the area above the bench which can still be bat cave storage. Don't underestimate how much of a toll standing on uneven ground for extended periods will take on your body.Good idea, but am wanting to create some storage spaces up in the bat cave void.
I still feel like I want to frame this in timber though… Don’t have a welder for a start, but feels like it will be easier to work around the wonky floor.
Reckon standing on that slope would drive you nuts, you'll also feel super tall at one end of your workbench and super small at the other!That's fair and I'm probably starting to move well outside the original scope but you could put in a small set of stairs to access the area above the bench which can still be bat cave storage. Don't underestimate how much of a toll standing on uneven ground for extended periods will take on your body.
