SummitFever
Decided to start promulgating a new standard to beat all rear axle standards. You take the stiffness of a 19mm hub axle in boost config, add some custom end caps that bring the width out to a clearly superior 152mm wide and insert the flexiest Ti QR skewer you can find. The combination of a super stiff 19mm axle, the big bearings and all the other German made goodness in the hub combine beautifully with the untensioned spokes. Super compliant for more traction when railing the berms. Also, stretching your rear triangle apart preloads the frame for additional stiffness.
Of course, its all laced to carbon hubs with mandatory alu (yes alu!) spoke nipples. Seriously, it doesn't get any better than this.
