Haakon
Just call me Elon
Anything from the GX assembly ditch, you only need what came in the baggy with the X01. You’ve guessed right on the loose o rings.Just in the middle of fitting the X01 kit....need some help...
Not 100% about which bits I need / don't need....?
I've got the SRAM exploded diagrams in front me.
There are 3 o-rings in the kit. One is already on the new B-Bolt. One is larger and loose. One is smaller and loose.
Smaller loose o-ring is a nice fit under the head of the new B-Bolt. Makes sense to keep muck out of the area between the B-Bolt sleeve/bush and the bolt shaft itself ?
Larger loose o-ring is a good fit on the frame/inner side of the b-limit plate?
The wave washer that was between my b-limit plate and derailleur....no longer used?....or retained??
It's shown in the diagrams for GX....but not X01...??
The retaining collar that stops the GX bolt from unwinding....No longer needed I'm thinking...??
There doesn't seem to be a groove/landing for it on the new X01 bolt....?
Be really careful and use grease sliding the sleeve and the tension plate over the b bolt, I mangled the little o ring on the b bolt...
