Little plastic bit and screw is different in that video. Pretty sure I followed some instructions similar to those when I first pulled it apart.
Loctite?Can I grab one of these? I’ve tried fixing mine 3 times now, somehow the screw keeps working loose resulting in the clutch being useless
Either that or tell me how to fix it
I've had a few go the same way. I reckon your bolt and black dealie will solve @goobags issue.......if you aren't needing it any more.Loctite?
I haven't had this slipping issue either.
Here is the issue with mine:
I think the little plastic piece on mine is still ok, if you want it.
Found a problem, whether it is the problem I am yet to find out. Bit of loctite first and we will see how I go.
