Second in line if op doesn't need the 150mm and your looking at selling it.Brand X are reliable, work well enough and easy to service. I have had 3 in different lengths (one used and 2 new) and they've all been perfect. I'm thinking of upgrading to a one-up only because I can fit a 210 dropper on the bike with one up.
If you are after a 120 or 150 31.8 cheap to try it out let me know.
Will let you knowSecond in line if op doesn't need the 150mm and your looking at selling it.
I had had 3 Brand X and all worked flawlessly. But the remortes aren't great or even good. I have replaced them with ZTTO remotes for about $25 a throw from Ali Express.Brand X are reliable, work well enough and easy to service. I have had 3 in different lengths (one used and 2 new) and they've all been perfect. I'm thinking of upgrading to a one-up only because I can fit a 210 dropper on the bike with one up.
I sent some grommets with the dropper. I sent a plug from my NS eccentic that came with it (needs a hole drilled out to use but will fit) as well as an electrical grommet eft over from from I built guitar amps years ago. Looks like he used the electrical grommet which looked very tidy when I did a test fit on the Eccentric which isn't built up. It looks perfect with the cable through it quannumNice. Where you get the grommet?
Since we have a store here:Nice. Where you get the grommet?
Thanks for the mansplain, Steve Jobs.Since we have a store here:
https://www.clarkrubber.com.au/products/725p-thick-wiring-grommet-thick-wiring-grommet
https://www.clarkrubber.com.au/products/722p-thin-wiring-grommet
Another one to try would be Wiltronics near end of ring rd.
Or order online from RS components...
Hambo it FFS, lol.
No problem! Happy to help you out anytime you need it buddy.Thanks for the mansplain, Steve Jobs.
If I get a ZTTO remote, can I use the existing cable or will I need to use new cable? I'm also have a Brand X.I had had 3 Brand X and all worked flawlessly. But the remortes aren't great or even good. I have replaced them with ZTTO remotes for about $25 a throw from Ali Express.
Unless the cable is only a few weeks old, it’s worth replacing it for the small outlay.If I get a ZTTO remote, can I use the existing cable or will I need to use new cable? I'm also have a Brand X.
It's not the outlay, it's the utter pain in the arse with internal routing.Unless the cable is only a few weeks old, it’s worth replacing it for the small outlay.
