hifiandmtb
Sphincter beanie
Well there you go:
https://www.rms.nsw.gov.au/document...vsi-27-mopeds-power-assisted-pedal-cycles.pdf
Now...where to find this "time" detail...2. Power-assisted pedal cycle - maximum power output 250 watts (a ‘Pedalec’) A ‘pedalec’ is a vehicle complying with the requirements of European Standard EN 15194: 2009 or EN 15194:2009+A1:2009: ‘Cycles – Electrically power assisted cycles – EPAC Bicycles’. To comply with EN 15194:
• The motor must be electric
• The maximum continuous power output of the motor cannot exceed 250 watts measured at the wheel Note: A motor that delivers 250 watts of continuous power can produce greater power for very short periods of time, which can be beneficial when pulling away at traffic lights or starting a hill climb.
• The rider must pedal the cycle to activate the motor*
• The motor must cut-off once the vehicle reaches 25 km/h, or sooner if the rider stops pedalling
• The vehicle must be certified by the manufacturer, and labelled as complying with EN 15194. The label must include the manufacturer’s name, the motor’s cut-off speed in km/h and its continuous rated power in watts.
* Pedalecs may be equipped with an optional low-speed start-up mode that allows the motor to power the cycle up to 6 km/h. This mode is activated by the user either when riding without pedalling or when the user is pushing the cycle.
