rockmoose
his flabber is totally gastered
I just nip into my garage and get 30kg me for the climb, and 300kg me for the descent.Just move your difficulty slider to 100%
Oh, and the magimix. I never jump on without my trusty kitchen accessory.
Invite a drove of similar spankers around for dinner, tell them 20km each before allowing them to nosh on your Chips, Chips and Cheezie.The fat stain has had two nights off... due to, well.... chips... chips and cheesecake.....
Can anyone suggest a group that does the PRL Half????
I managed to get it down the alpe. Pure dumb luck, but if you time your max sprint effort with a steep bit, it must work. I got to 98 and was cooked. Had already decided to give up and decided fuggit, I'll empty the tank one last time. Thought I was going to black out.Apparently the trick to getting the 100kph badge is to climb the Radio tower, then change to your most aerodynamic combo at the top, TT bike and whatever flash wheels you have at level 35
Then gun it down the descent.
I only reached 92kph last night on the Canyon and Mellies, looks like a 660w peak.
If you get an Aero Boost at the top, you can supposedly hit 105kph on at TT bike with 700w input.
Means I'll have to climb it again some day.
What does your virtual badge get you?I managed to get it down the alpe. Pure dumb luck, but if you time your max sprint effort with a steep bit, it must work. I got to 98 and was cooked. Had already decided to give up and decided fuggit, I'll empty the tank one last time. Thought I was going to black out.
Virtually nothing.What does your virtual badge get you?
An 18% boost in onlyfans subscribers.What does your virtual badge get you?
So if @Mattyp earns his virtual badge then you would instantly increase 18% in weight?An 18% boost in onlyfans subscribers.
I think that's how it works, and @Cardy George gets a 26% boost in his ability to snare hamsters. Or something.So if @Mattyp earns his virtual badge then you would instantly increase 18% in weight?
Hamsters? If you can't handle full sized roos you're useless round these parts.I think that's how it works, and @Cardy George gets a 26% boost in his ability to snare hamsters. Or something.
Livestock, elevation, property prices.Hamsters? If you can't handle full sized roos you're useless round these parts.
just curious, can #2 son afford his own computer? he could use the Zwift shitbox until he buys his own, or will that cause a cascading chain of nuclear tanties?I had a moose-drop out today, was a pretty big ask to transmit Bluetooth 7metres through glass and double brick.
1st sign was my TickR Bluetooth dropped out at a couple of km in, no big deal, then the trainer dropped out stopped a few hundred metres short of the Radio Tower turn off... oh well, at least I got to save it.
So now I have shifted the Zwift setup from one side of the room to the other, pulled the Bluetooth card and poked a dongle out through the internal window so its now looking at the Trainer at about 2m distance.
I have used the Bluetooth 4.0 dongle with no issues from the start, just upgraded later to Bluetooth 5.0 but it was an card inside the computer... now defunct.
The Quest for HD graphics. Will try again tomorrow.
#2 cant afford a $1 Frozen coke from HJ's.just curious, can #2 son afford his own computer? he could use the Zwift shitbox until he buys his own, or will that cause a cascading chain of nuclear tanties?
