Pink/purple and the gold, whatever those versions are. I think ceramic and full metal. Like I mentioned though, the poor braking could potentially have been the overall setup or something else at the time so definitely need to revisit.With both resin and ceramic or just one of them?
Wow mate, your full order history looks earily similar to my own.
Have you been happy with the bearings?
Isee you got a spoke tension meter. Those aliexpress pro truing stands are worth it if you ever get into wheels and need one.
This is the stand I bought. I paid $282 delivered in 08/2021. Price seems to have gone up since then.I haven't looked at stands. What's the benefit of a stand?
I have one of these which is similar but not the same.$27 digital shock pump. Someone here said they work well.
40.95AU $ 47% OFF|Portable Tire Tube Pump 320 Psi Schrader Valve Manual Bike Fork Rear Shock Pump Digital Display Cycling Accessories
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I tried to order one a while back but it didn't arrive. Logged on to AE last night and seen this in my basket, it had dropped in price from $35.I have one of these which is similar but not the same.
Just got my elita1 cabron saddle.
I've got a similar saddle that I've never used. Does anyone know if you're meant to use different adaptors for the carbon rails? It's just I noticed there are different adaptor clamps available for them.Just got my elita1 cabron saddle. Looks pretty mint. Minimal padding. Arrived in a box, packed in foam, and with a dust cover.
Lightest saddle I’ve ever owned.
Will wait and see what the durability is like. Hopefully I don’t get splinters in my cheeks.
I just used the same clamp. Apparently it’s only side clamps you can’t use with oval rails?I've got a similar saddle that I've never used. Does anyone know if you're meant to use different adaptors for the carbon rails? It's just I noticed there are different adaptor clamps available for them.
I ran a AE carbon post for a while without issue and a carbon railed WTB Volt without babying it. So long as you don't crush the rails by over-tightening, I'd be surprised if you run into issues under normal use.Just got my elita1 cabron saddle. Looks pretty mint. Minimal padding. Arrived in a box, packed in foam, and with a dust cover.
I’ve got the one u linked.https://www.aliexpress.com/item/33033055789.html
I'll also need 6902 and 6805 bearings. Am I best off ordering these from somewhere like diymtb, etc.. or has anyone found anything good on aliexpress?
Rode the saddle on Sunday. Comfortable flex. Uncomfortable thin pointy nose that stabbed me in the thigh. Need to get used to that. Probably needs some tilt adjust.
Had one OTB where my saddle hit the ground and seatpost spun a little. Still in one piece. No cracks.
