So not much change between new and old then except for a few grams and the black stanchion! Let us know how it feels after a few rides. I am happy with the Giant Contact Switch except for the dropper will extend if you pull up on the saddle. This means if you sit right back and then move forward and your shorts catch on the saddle it will cause the height to rise. Very annoying and a bit dangerous.
Yeah not sure if I will go as wide as yours due to risk of rock strikes etc. 25 to 27 mm will be good I just want the extra stiffness and less tyre roll. I can hear the tyres rub on the frame sometimes.
yeppp, apart from a few grams...AFAIK internals are the same.
I have a mate that runs a Contact post and I know exactly what you mean. With the dropper maintaining height one pulled on.
There also seems to be serious left/right play? the other weakeness I read was the rail clamping design is really poor?
...def consider the Lev when its time for an upgrade, BUT CARBON WHEELS FIRST !
with a shock pump armed and ready, I took the bike out for a ride.
forks are PLUSH.... really plush. I see all the hype people speak now! far less stiction than the 34's.
fiddled abit with rebound and LSC... but need a knarlier track and more time to really dial it in... so far. I'm very happy.
also got to test out my new helmet!
I sold the super comfortable TLD A1 to Ev a few months back , as I found it wayyyyy too Hot !
My body simply doesn’t sweat (even on the hottest of days), consequently my body just cooks from the inside. So I needed a cooler helmet!
Enter the Met Parabellum !
Tried on both the M and the L... and ended up getting the Large(59-62) -335ggrams
Hopefully the weight means it sits lighter on the head/hair to give more air flow? (something the A1 really struggled with!).
Love the inbuilt ‘MOPOV’ adaptor (similar to the Bell Super), where it lets you attach a camera…. but a better use I have found is a light mount
after some playing around with mounts/adaptors/link. I came up with this!!! super low, and sleek!
Really happy with the helmet! Not as comfy as the A1 (not that its uncomfortable)… but much better airflow and much cooler which was what I was after!
