So another night ride last night.
I'm pretty happy with my fork settings. Supple off the top, but hold up well in the middle, and rarely gets near full travel. Will play with air pressures some more. But generally liking the Mezzer. It's super stiff too, which is nice coming from a Fox 34 (and pushing 85kg at the mo).
DPX2 rear shock is harder to get feeling good.
Things I've tried:
Left it per stock config, and set sag at 15mm. Rebound adjustment range is fine. Played with LSC, but don't feel big differences. Shock felt quite dead, like it has 10mm of softness, then ramps up wayyy to quick and bigger hits feel like a deadblow hammer.
Pulled the 0.6 volume spacer out over the weekend and reset sag to 16mm (16/55 = 29%). This is just outside Banshee's recommended 13.5-15mm. It feels like my travel is more useable now.
Will also try less sag, maybe 25% (around 14mm) more in line with recs.
Might also try putting a smaller vol spacer in rather than none, or just a little whack of slickoleum perhaps if I can't be bothered with the spacer kit.
Eventually I might want to grab a coil. The mezzer is just so plush that I don't know if I'm going to find a setting on the shock that gets me close in feel to the fork.
When setting sag, i notice there's a weird part near the top of the stroke where the shock feels like it gaps through part of it's travel without resistance. Was mulling over it all night, and realised this morning that it'll be where the dimple is to equalise the negative space. Feels shitty when I'm sitting and bouncing near the top of the travel, but I haven't noticed it out on the trails.
Overall still liking the Prime frame. May try a 45-50mm stem at some point. I've got a 35 on there at the moment, and it's perhaps a tiny bit short. Could use a little more weight over the front when it pushes on sandy/loamy corners.
