dancaseyimages
Mountain bike pornographer
Saw this on special so decided to bite the bullet, wasn't sure on the colour at first as its not quite a normal red, more like a faded commodore red colour.
Wrapped in FrameSkin.
Frame - Transition Scout Medium
Rear shock - Fox Float X Performance 2 Position
Front shock/fork - Fox Float 36 Rhythm 150mm Travel/37mm Offset
Handlebars - RaceFace Chester 35 780×35
Stem - RaceFace Aeffect R (40mm)
Headset - FSA No.57E
Grips - DMR Brendog Death Grips, Flanged, Thick Soft Colour Blue/Pink
Saddle - ANVL Forge Cromo
Seatpost - OneUp Dropper Post 180mm
Front brake - SRAM Code R, Rotors SRAM Centerline (180mm)
Rear brake - SRAM Code R, Rotors SRAM Centerline (180mm)
Cranks - SRAM Descendent 6k DUB (30t-165mm) (Wrapped)
Chainguide - E-Thirteen TRS+ Single ISCG 05 Chain Guide - ISCG 05 - 28-34T - Black (swapped stock spacer for stainless washers for a cleaner look.)
Chain - SRAM NX Eagle
Pedals - Deity TMAC Alloy Flat Pedals - Bronze (Big and pretty flat pedal, minimal concaveness)
Front derailleur - N/A
Rear derailleur - SRAM NX Eagle
Front shifter - N/A
Rear shifter - SRAM NX Eagle MMX
Cassette - SRAM PG 1230 (11-50t)
Front hub - Novatech D791SB
Rear hub - Novatech D902SB
Front rim - Stans Flow D
Rear rim - Stans Flow D
Spokes - Pillar Double Butted
Nipples - Yes with gold nip covers
Tyres -
FRONT Maxxis Assegai 3C EXO+ (27.5×2.5)
REAR Maxxis Minion DHRII 3C EXO+ (27.5×2.4)
Tubes - N/A
Total weight - 16kg with all the fruit
Front shifter - N/A
Tyres -
Tubes - N/A
