stirk
It's bloody mandatory in my opinion, and I don't care what gender you are.Do you wear sports shorts over your lycra bib knicks?
Oh good I wasn't sure if I was doing it wrong! I do find they slide around a bit though..It's bloody mandatory in my opinion, and I don't care what gender you are.
If your bits a sliding about something is wrong.Oh good I wasn't sure if I was doing it wrong! I do find they slide around a bit though..
My shorts slide around. Not sure I needed to explain that!If your bits a sliding about something is wrong.
The chamois butter goes on the inside.My shorts slide around. Not sure I needed to explain that!
If I told you, I'd have to kill you.Is that full stop. supposed to be there?
If I saw you, I'd want you to kill me!If I told you, I'd have to kill you.
I do that stuff with my eyes closed.If I bedded you, I'd want you to keep seeing me.
How bad to you want to find out?Would self administering an epi-pen in the absence of anaphylactic shock cause my heart to melt?
From a G!ants website - listed under the full specs for each bike, hope it helps clarify:Who do I have to kill to find out the max. rider weight for a Fox CTD shock?
The max weight is determined by the sag which is set by the pressure. I can however confirm that my Fox CTD functioned as intended well north of 130kgsWho do I have to kill to find out the max. rider weight for a Fox CTD shock?
I can see this ending badly in the fuckwits thread....Just gotta try and squeeze more air into the bastid thing then, I guess.
I'm a lil' south of there, so I should be fine.The max weight is determined by the sag which is set by the pressure. I can however confirm that my Fox CTD functioned as intended well north of 130kgs
I'll keep you updated!I can see this ending badly in the fuckwits thread....
*I can see this ending well (for our entertainment) in the fuckwits thread....
NOT medical advice but...I don't think it will have any negative impact.Would self administering an epi-pen in the absence of anaphylactic shock cause my heart to melt?
Shock max psi, leverage ratio of frame, no set rider weight...pump harder!Who do I have to kill to find out the max. rider weight for a Fox CTD shock?
