awesome! Both you and @birddog69 are both champions!View attachment 406022
Have silver or black if you’re still chasing one.
PM me your postal details, can post tomorrow
Got a bike shop nearby? Popping and seeing if they have a bolt in their workshop?Revisiting this thread.
So Vanderly industries kindly sent me a bracket but sans cap head bolt which is no drama as I have plenty.
Turns out I don’t.
The SRAM bolt that goes in it is an m5 thread with a smaller than standard(Bunnings) cap head and my local bolt place has a ridiculous minimum order. I’ve got plenty of m5 bolts but the heads are all too big to fit in the pocket.
so I need a m5 with a 7mm cap head. Not the 8.5 cap head off standard bolts.
anyone happen to have either an original sram bolt or a suitably sized one?
I’m happy to pay for it and also express postage as I’m heading off on a bike trip on Friday. Hoping to get it before then.
Five minutes on a bench grinder would solve that.Revisiting this thread.
Turns out I don’t.
You’d think so but by my scientific calculations there’d be fuck all perimeter left around the socket. That will be a last resort.Five minutes on a bench grinder would solve that.
Thanks. I’ll have a look.I use https://www.boltandnut.com.au/bolts for obscure fasteners that I only need a few of, usually pretty quick delivery.
Could go not just file the head down smaller? Something like that I'd put the threaded end into a battery drill and use it to do the work.
I've never seen the originals, only used the clamp parts to make dodgy ispec mounts. Do the ridgy dij ones have a reduced hex size in them?You’d think so but by my scientific calculations there’d be fuck all perimeter left around the socket. That will be a last resort.
Yep. The reduced once have a 3m hex and the normal size are 4mm so by the time you turn it down there nothing left. I don’t have the same life changing issues with Sram that some people seemingly need to have therapy about but in this case they can go eat a bag of diks.I've never seen the originals, only used the clamp parts to make dodgy ispec mounts. Do the ridgy dij ones have a reduced hex size in them?
You monster!Can you bodge it with a longer bolt and some washers underneath so the bolt sits above.
That should read bolt head. Ha ha. A bodge may get you though until you can source a bolt.You monster!
I’m running the shifter with a matchmaker currently but the ergonomics aren’t ideal so it’s not the end of the world to run it like that. The bracket is curved where the cap head sits on so longer bolt bodge won’t really work.That should read bolt head. Ha ha. A bodge may get you though until you can source a bolt.
