wtr
Evening, farkers.
A mate of mine owns an auto FC3(RX-7), and has been experiencing strange spontaneous surges lately. It seems though when he shifts to neutral, she just revs up and fluctuate between 3.5 - 4rpm. when he tapped the gas gently thinking it might be the throttle cable playing up, she steps up revs even more and continues to fluctuate. So far the only solution is to restart her, and the problem will be gone until next time when it manifests again. Normal idling was tuned by a shop to sit at 1.5rpm, which I think is a bit high...
She remains a stock except for a custom radiator, although the air flow meter has been slightly positioned on an angle due to piping. The boost sensor has been unplugged to avoid fuel cut.
With the cooler sitting above the throttle body, he's reluctant to take it off. I've had a look around for loose/disconnected vacuum hoses and found nothing but a hose with a filter of some sort unplugged, the hose neither sucks or blows. See circled area.
She also has a tendency to flood herself just before shut down. with all these symptons playing up, could it be the ECU along with a few loose vacuum hoses?
He's due to go oversea soon in 7 days and won't be back for 7 months, and is desperate to know what's wrong so he can at least leave with an answer.
Your valued inputs will be much appreciated.
