Definitely replace cables first. Depending on how it routes, some bikes are just naturally heavy shifting due to all the kinks and bends. You don’t have cables clamped down too tight anywhere?Missus is complaining her shifter is too hard to downshift. Shifter is an 11speed XT and derailleur is SLX.
What options to lighten up the shifting?
Was going to replace all cables.
Should I be considering XTR shifter?
Indeed. Spitty are beautiful routed for light shifting. Check the clamping, then I’d definitely change inner and outer as first option.The bike is a Spitty so not really any sharp bends,
but didn't think about the clamping of the cable, will have a look.
Can try backing the clutch off...
Thanks for the offer, I'll check the cable first. Send you a PM if that doesn't help...I find the SLX 11s shifters much lighter shifting than XT.
I probably even have a spare here if you want to try it. Ispec 11
GX isn’t bad. I’ve only paired one to a GX derailleur. Quinn’s is X1 to XT, so I can’t compare directly.Not really up with SRAM gear. Is a GX shifter reasonable?
I've read this doing research on the 12 speed stuff, seems to be the general consensus. Stopped me chasing a XT shifter upgrade.SLX shifter noticeably lighter. When changing up previously the increase in effort was disappointing.
I can’t say I found that in 11sp. That said, I only used one for a short period.I've read this doing research on the 12 speed stuff, seems to be the general consensus. Stopped me chasing a XT shifter upgrade.
Thanks to covid, I don't have any real-world dataI can’t say I found that in 11sp. That said, I only used one for a short period.
Yeah I had been using SLX for a couple of years and upgraded to XT, love the double downshift but was a shock how stiff the upshift was.SLX shifter noticeably lighter. When changing up previously the increase in effort was disappointing.
Yes running 46 largest cog.Are you running a cassette bigger than 42? I found the extra B screw needed to pull the derailleur back to clear a 46 also added resistance in the big cogs.
I have a few of both. I’d say xtr is crisper, but not necessarily lighter.I have xt and xtr, xtr is a lot lighter to shift. Both are sensitive to b screw adjustment.
