AM Second Time Lucky (Craftworks FRX V2)
Lucaw
Capital punisher
After a 15 page wanted thread and a broken frame I have finally complete my new single pivot craftworks FRX
thank you to @nexusfish, @clockworked and a massive thank you to @ozzybmx for picking up and sending it to me
375665
375666
Frame - 2011 CRAFTWORKS FRX V2 drilled out to fit a internal dropper.
Rear shock - RockShox Ario 3.0 fox dhx 5.0
Front shock/fork - RockShox Revelation 2014 Marzocchi bomber 44 Marzocchi 55 rc3
Handlebars - 35mm black riser bars 740mm wide
Stem - titec el norte 35mm
Headset - FSA gravity
Grips - canyon
Saddle - wtb sdg lapiere
Seatpost - funn up down 150mm internal
Front brake - sram level T shimano xt m775
Rear brake - sram level T shimano xt m775
Cranks - Shimano SLX hollow tech 2
Chainguide - e*thirteen isg old
Chain - box hex lab shimano 9 speed
Pedals - raceface chester composite, blue
Rear derailleur -box 3 prime nine microshift advent 9 speed clutched
Rear shifter - box 3 prime nine single press microshift advent 9 speed
Cassette - box12-46 9 speed cassette
Front hub - da bomb head spin
Rear hub - hope pro 2 evo 12x135
Front rim - stans flow mk 2 white
Rear rim - stans flow mk 2 white
Tyres - 26 x 2.5 minion dhf exo front and 26 x 2.4 minion dhr 11 dh casing
Tubes - kenda
Total weight - I don't know, but light enough to carry
Lucaw
Capital punisher
Hows the tyre clearance?
After I was jumping of retaining walls at school, a small nick has appeared on the back of the seat tube :eek:
So, I put an old fox 32 seal over the end of the shock, meaning that there is a decent gap between the rear wheel and the seat tube.:D
Plankosaurus
Spongeplank Dalepants
You might be able to get a spacer on the damper shaft inside the shock. Worth a look, I feel like that'll work a lot better than something jammed over the outside of the shock.
