In that case smooth out the high spot. The loss in area will not be noticeable.
I heard that also, measured the bore on the Rev's with telescopic gauges and it was the same size all the way through. You need to hone the lower legs to help the new bushing go in easily as you score the bore removing the old bushes and mine were very tight to remove also.I've swapped bushing in 32mm SIDS, had to make tools too. Washer with flats for removal, lowers with an old bushing pinned on to push against the new bushing.
The SIDS have/had a taper on the inside of the lowers, inserting the bushings further in set the gap, but they were 2012 sids, not sure about latest generation and setting gaps.
Fox are cunts too. They don't sell most tools and small parts to the public nor do they share much of their technical service information.Fark me, and people bag fox forx. These rock shox scum need to be black banned by all you new fork buyers. Non replaceable parts like that are just dodgy money making ideas, 600 to replace one worn part.
I am not taking the piss but all you RS fans should be outraged
thinking of an x fusion McQueen if I can find a cheap one.Buy a Mattoc........
Brand new pro2?thinking of an x fusion McQueen if I can find a cheap one.
Where re would one find a good value mattoc?
^^^ This. That damage to the surface layer of the bushing is nothing. That same bushing on the SID has large (6-8mm?) holes in it to save weight.In that case smooth out the high spot. The loss in area will not be noticeable.
You need to get onto Cyclinic!!! (https://www.cyclinic.com.au)Fox are cunts too. They don't sell most tools and small parts to the public nor do they share much of their technical service information.
Talked to the boys at Cyclinic and they said new lowers very polite and professional in their response.You need to get onto Cyclinic!!! (https://www.cyclinic.com.au)
The guys there are ridiculously helpful, and their webstore stocks most everything (and pretty sure they're willing to help with anything that's not listed).
Most of the Fox servicing is up on their website now the only stuff I have trouble finding technical documents for are the collaborative items like RE:aktiv, Gemini, DRCV, etc.
But OP's problem is ridiculous. You can buy second hand entire forks for the quote they've given you on the lower there. Have you contacted a suspension servicing company to see if they can quote you on a fix? You'll be up for a servicing fee at the very least, plus some parts (but bushings are cheap). If they do offer a solution I imagine it'll come in at about a third of the quote already given....and services the fork at the same time.
Do what ever you like but I honestly think you're making a mole hill into a mountain. You just need to remove the high spots, you've already got oil reliefs slots that have decreased the bush contact surface area, that little bit more isn't going to hurt it.Talked to the boys at Cyclinic and they said new lowers very polite and professional in their response.
I've spoken to and sent the pic to Mountain Bike Suspension who think they can help out. So fingers crossed.
Trying to find 2nd hand boost forks is proving a challenge.
I'm glad everyone is positive of a fix for it.I would repair that for you if I was local. Very simple fix.
I hope that's just a euphemism. The bushings are a type of tin/brass metal with a teflon based glide coating which is around 0.5mm thick. Any sort of abrasive hone will leave grit particles embedded in the glide coating. This will destroy your stanchion in the blink of an eye. In addition, the bushings are factory inserted into a tapered bore at a depth that will ensure the proper fit with the stanchion. Removing any material except the high spots at the point of damage will bugger the bushing. There is no way to properly use a hone to remove the damage shown. The end of sharp knife is the only way to go....through the hone to remove without doubt the high spot...
yes mate it was. They are just trying to remove the high spot if they can. I'm fine by shops being cautious but have felt encouraged by the advice here.I hope that's just a euphemism. The bushings are a type of tin/brass metal with a teflon based glide coating which is around 0.5mm thick. Any sort of abrasive hone will leave grit particles embedded in the glide coating. This will destroy your stanchion in the blink of an eye. In addition, the bushings are factory inserted into a tapered bore at a depth that will ensure the proper fit with the stanchion. Removing any material except the high spots at the point of damage will bugger the bushing. There is no way to properly use a hone to remove the damage shown. The end of sharp knife is the only way to go.
I am amazed at the bad advice you have received from 3 shops and a "suspension guru". Perhaps this is explainable on the basis they want to sell you a set of lowers at 60% markup?
I find it hard to believe that the bore for the bushes are tapered, 1. you would have damaged the bottom bush hitting it through the top tapered bore, 2. it will distort the bush big time and it will not sit parallel with the stanchion because you would have needed some sort of matching taper on the outer of the bush. All the rockshox forks I've seen from factory have the top bushes installed flush, if there's a taper there for adjustment I would have expected to find them to be hit in all over the place. I read some of the early posts on here, decided to measure mine with telescopic gauges and they proved to be straight machined bores.I hope that's just a euphemism. The bushings are a type of tin/brass metal with a teflon based glide coating which is around 0.5mm thick. Any sort of abrasive hone will leave grit particles embedded in the glide coating. This will destroy your stanchion in the blink of an eye. In addition, the bushings are factory inserted into a tapered bore at a depth that will ensure the proper fit with the stanchion. Removing any material except the high spots at the point of damage will bugger the bushing. There is no way to properly use a hone to remove the damage shown. The end of sharp knife is the only way to go.
They are only doing this to cover themselves. They sure as hell wouldn't want to risk saying it'll be fine, then the OP comes in furious at a worn stanchion based on that advice.I am amazed at the bad advice you have received from 3 shops and a "suspension guru". Perhaps this is explainable on the basis they want to sell you a set of lowers at 60% markup?
