I have a Panasonic mini system connected to my PC for all audio. Using the red/white ports on the mini system and the green audio port on the PC. Today I moved the mini system to another location, and noticed that I was only getting audio from one speaker.
I swapped the cord for a spare I had to check if it was the cable or the actual port on the mini system (Been using a 4m one, the spare is 1m) and found the same problem – only reversed – only audio from the other speaker.
I'm not sure what caused the problem initially, and why the problem is reversed when I use a different cord?
